Question about Dishwashers
The on switch is frozen and does not turn on whirlpool dish washer mod du8108wpq3
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 143 Answers
Try putting some penetrating oil on the joint that is corroded/ ruusted/stuck, let it sit a day and try working the shaft back and forth a little. If you cannot free the shaft, replace the entire timer assembly
Posted on Oct 03, 2009
How do I unlock my washer
im gessing its a front load.. under the door switch there is a plastic tab that you pull about 1 cm down it aint easy to reach but its there you need to slide your hand in there and feel it
Oct 04, 2014 | Whirlpool duet Washing Machines
Dish washer lights dont work and will not run
Prabably no current running throught the dishwasher or a breaker or
somethings disconnected also the button or turn on or off switch mmay be bad
Aug 23, 2012 | Whirlpool Gold Series 24" Tall Tub...
Need instruction manual for whirlpool dish washer mod. DU930PWQ2
Are you sure about the model number? The Whirlpool dishwashers that start DU930 have 4 letters in the model number after the 930.
If your model is the DU930PWPQ2, the manual is available here: https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208575990.pdf . If you have a different model, try looking it up here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=m3wLp9EUOpUUfCAXtvB5kw%3D%3D&ddkey=http:WHRHelpContactUsSendMessage .
I hope this helps.
Apr 26, 2012 | Whirlpool Dishwashers
Mod. 110.29852992 80 series will not pump out
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.29852992&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
See the following for how to access the console and Lid Switch connection.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6f8112b458c05fcc8f6d1a4139b9a723
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
It also has a troubleshooting guide.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips,pull the console forward and tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
May 12, 2010 | Kenmore Washing Machines
Kenmore mod 23832100 Lid Switch broken HOw do I
Good day,
There are 3 different style lid switches used on Whirlpool/Kenmore washers. You have to break down the unit to determine which one you use. Any appliance parts house will carry what you need.
Here is an excellent tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 01, 2010 | Kenmore 23822 Top Load Washer
MY whirlpool dish washer is stuck on "clean" status and light is juts blibking on and off
See this thread:
http://www.fixya.com/support/t157405-clean_light_dishwasher_stop_flashing
Sep 06, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
Owen Barnes
