Question about Apple Computers & Internet
Headphone snapped off in jack so lack of sound
Part of a headphone plug has snapped off and been left inside the headphone jack so all sound is trying to pass through there, meaning i cant get an sound. what product should i buy to re route the music via usb
  • 1,305 Answers
If you want, you can open the laptop up and attempt to remove the broken piece.
Go to powerbookmedic.com and you'll find free pdf's on how to open up your particular laptop... It may save you some bucks!
most macs are easily opened and if you need a replacement part, their website has most available...
good luck..
k
Posted on Oct 14, 2009
Denon 1908 no sound
Try inserting a headphone plug into the headphone jack and remove it. Sometimes these units have a problem in the headphone jack where the unit thinks there are headphones plugged in even when there isn't. This cuts all the audio output to the speaker jacks. If you never plan on using the headphone jack, you can also go inside of unit and unplug the cable that goes to the headphone jack board. Just make sure you unplug the unit before you do this, the plug is close to the main power switch.
Feb 22, 2013 | Denon AVR-1908
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
May 26, 2011 | Dell Latitude D600 Notebook
My left earpiece in my sentry headphones have no sound. How do I fix this?
Check the plug - it might have a broken wire, by wiggling it in the jack. It could be the jack as well - try another headphone in the jack.
Nov 08, 2010 | Sentry HO900 Headphones
I have bought a pair of Shure SE210 headphones for my iphone but the sound is lacking all the low frequencies for most of the music or videos i try to play. The headphones work perfectly on any other...
No, there are no known issues. Typically a lack of bass response is due to a poor seal with the ear canal. The headphones use sealed ear canal is a resonant bass chamber. Thus, if there is not a good seal, the bass will be significantly lower.
Jul 07, 2010 | Shure SE210 Consumer Headphones
Harman-Kardon HK695-01 Speakers Connection Quesion
According to the manual
http://tv.manualsonline.com/mdownloads/14ae515f-03bc-a2d4-8940-672bfa19f017.pdf
leave the black connector unconnected.
Hope that helps.
Oct 02, 2009 | Harman Kardon HK695 Computer Speakers
Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Feb 26, 2009 | Marantz SR7500
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Ron
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
Audio only plays from left headphone
The contacts inside the headphone jack are made of a springy metal there is one for the left and one for the right speakers. This happened to my Blackberry and I took it apart and got inside the jack block and re-sprung the contacts. It worked for me... I used a dental pick.
Nov 09, 2007 | Kingston Kpex100 Digital Media Player
Computers & Internet Logo
96 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
