Question about Jenn-Air JGR8850 Gas Kitchen Range
F9 message I have a 9860AAP. The oven will not work. I keep getting the F9 message. How can I fix this?
  • losguilarte Oct 03, 2009
    The door latch mecanism works fine. The message is still there. The groove on the oven door where the latch fits seems to be bent out on one side like it was forced to open. Will make it flush by hammering work?
    The unit is five years old, although it has never been used.
    President:
  • 1,653 Answers
The F9 fault code is for the - Door Latch. Check door latch switch is secure and wiring for any damage or disconnection. If you have a voltmeter and continuity tester you can soon see if the latch and switch are working correctly.
Posted on Oct 03, 2009
  • Karl Wright
    Karl Wright Oct 03, 2009
    Hi again,
    Forgot to add that if your oven is a newer type then the F9 code will mean that the Door Lock Safety Circuit On Power Relay Board Sensed and you will need to replace the power relay board. After doing this the oven will work.
    President:
  • 1,865 Answers
F9 is a door latch error. You have to check the door latching system for functionality
  • buffalonyman
    buffalonyman Oct 03, 2009
    F9 indicates a problem with the latching system, you have to repair it
LG double oven shows f9 code in both ovens
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Nov 19, 2013 | LG LWD3081ST Electric Double Oven
I get an F9 error message when I try to set the oven to bake.
THis is what the F9 error code means;
F9 Door latch failure Replace door latch switch or assembly if necessary
Aug 20, 2011 | Ovens
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
Keep getting LIN Wait message after we unplugged stove for 30 seconds following and F9 fault codee.
i had same problem with this oven at first (just installed last week). resetting it cleared it for a while and I got one (test) cycle out of each oven, but now nothing starts and I only get F9 message. also the clock and door switches are all screwy. I called mabe canada and they will dispatch a tech to investigate this as a "DOA" sigh.
Jul 20, 2010 | GE PT925SNSS Stainless Steel Electric Oven
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
F9 Error during self cleaning cycle
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 31, 2010 | Ovens
Set oven to clean, get flashing door indicator lig...
If this is an Electrolux oven then F9 relates to micro-processor resets itself.To get this to reset fully its reccomended that you disconnect the unit from the electric supply and then reconnect then retry.
Hope this helps
May 10, 2010 | Ovens
Oven wont turn on and gives F9 message
I UNPLUGGED THE OVEN FOR 10- MINUTES, THE PLUGGED IT IN AGAIN AND HELD THE CANCEL BUTTON ALONG WITH CLEAN FOR 10 SECONDS. THIS CLEARED THE PROBLEM.
Feb 08, 2010 | Ovens
F9 Code after power outage - Model JGR8855ADS
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Generic:
Fault Code Interpretation Components To Check
F-1 Communication error between touch pad and ERC (clock)
Replace the touch pad or clock.
F-2 Oven temperature sensed by electronic control Replace the clock/relay board
F-3 Open oven sensor or harness. Replace the oven sensor
F-4 Shorted oven sensor or harness Replace the oven sensor
F-5 Power to element relay disabled in cook mode Replace the clock/relay board
F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
F-8 Shorted meat probe Replace the probe jack.
F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
F-C or F-0 Communication error between boards Replace the relay board
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Mar 09, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
Double 27" oven Model No.911.48489 show F9,later beeping
The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
Oct 02, 2007 | GE JTP85 Electric Double Oven
Jenn-Air JGR8850 Gas Kitchen Range Logo
289 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
