Question about HP Computers & Internet
Got error message no bootable cd in atapi cd-rom
Got error message no bootable cd in atapi cd-rom on hp laptop computer won't boot
    President:
  • 1,865 Answers
Check your bios to make sure that it is set to boot from your HDD. If this setting is correct, perhaps your HDD is failed
Posted on Oct 03, 2009
Testimonial: "thanks I think it is a HDD problem"
No bootable CD In ATAPI CD-ROM
I think I know exactly what is causing your laptop not to boot from CD.
You need to get into the BIOS, go to boot options and change it from "EFI" to Legacy Boot"
Then when you restart hit the boot menu button to display a list of bootable devices, then highlight CD. and then boom now you are bootin gfrom CD!
Oct 20, 2013 | Sharp Computers & Internet
My computer won't boot up with windows xp service pack 3
This is a strong indicator the hard drive has failed, have it tested before replacement.
Jul 10, 2012 | Toshiba Tecra Computers & Internet
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
Ntldr is mising
Related errors
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32.
Solutions
Feb 19, 2011 | Microsoft Computers & Internet
Ntldr cd boot fault
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
Mar 31, 2010 | Computers & Internet
No bootable cd in atapi cd rom drive when i boot my laptop and also says media test failure check cable
if you can remove your cd drive there should be a button that you can hold to one side to take it out - if your laptop is not under warranty then there may also be some screws you can remove to take the cd drive out and re insert it to make sure its seated firmly.
Also just a simple thing - you have not left any cd in the drive have you ?
Sometimes if i forget to set the bootable order back to booting from the hard drive and I have the cd drive set to the bootable drive only and there is a disc in the drive or nothing in the drive it will display that so may be worth while checking your bios to see what boot order it has and disable the cd drive as the bootable drive if its in the list and set your hard drive to be the bootable device.
Apr 11, 2009 | HP LaserJet 1200n Printer
Boots to "no bootable CD in Atapi CD-Rom", Thne press F1 when ready
Sounds like dovidl2120, you have a non-bootable disc in the drive. Remove it and the problem should go away.
Nov 02, 2008 | HP LaserJet 1200n Printer
Can't swich on laptop after restarting it.
You have a non-bootable CD in the CD drive and the startup sequence is looking at the CD drive before the hard drive. Remove the CD and you should be able to boot.
Dan
Mar 20, 2008 | Computers & Internet
Computers & Internet Logo
235 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
