My blower wheel on our nutone 9093 vent fan keeps
My blower wheel on our nutone 9093 bathroom vent fan keeps slipping down off the motor shaft...how do I fix this?
Parts list and assembly drawing do not show a snap ring or any part to hold the wheel on the shaft.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 143 Answers
Buy a tube of Household Goop, and put some on the front and back of the hole the motor shaft goes through and glue the wheel in place. Make a little 'pile' or filet around the shaft/wheel joint. Let it dry a couple of hours.Goop is extremely handy, sticks like glue should, stays flexible, is cheap, etc.
Posted on Oct 03, 2009
Nutone bath fan how do you clean the vent
Usually the vent cover pulls straight down, and is held in place with 2 V-shaped metal spring wires.
Squeeze each spring wire together to release cover from ceiling box.
Use vacuum to clean vent fan housing. Some vent fans can be disassembled and motor housing removed for cleaning. Do NOT use water on electric motor. Simple vacuum, or dry toothbrush cleaning is good enough.
Spay tiny bit of WD40 on the fan motor shaft or add tiny dab of white grease if desired.
The plastic cover can be scrubbed with soap and water, rinse to remove soap residue, and when dry, paint with aerosol spray paint using 3-5 very light coats applied in 5 minute intervals.
Jul 28, 2012 | Broan-NuTone Fan,Bathroom Exhaust Broan...
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
The blower wheel slipped down on the spindle which is attached to the motor. This caused the blower fan to freeze up.
Remove the grill/globe and then the light fixture inside. This should provide you access to the motor just enough to move the fan back up the spindle.
Jan 25, 2010 | Broan-NuTone N-8663RP Combination Light...
NuTone bathroom fan starts slowly after being off awhile
need to blow it out with a air hose and oil it real good! but keep a eye on it to make sure it does not get hot! if it feels hot to touch replace the motor!
Nov 03, 2009 | Broan-NuTone (668RP) Fan
Where can I get the motor unit to replace?
The motor is a common item to need replacement in bathroom vents. Replacements can be found just about anywhere that deals with electric motors. You might even be able to get a replacement where you originally purchased the unit. There are dozens of web sites that you can locate a replacement. http://www.electricmotorwarehouse.com is just one. Simply do a web search on replacement bathroom vent motors. Also if the are able to purchase items from wholesale vendors you can get one from Grainger's. It should cost around $20 to $25
Part # 62345-000 (replacement motor part #).
However there is an alternative to replacement. This depends entirely on how handy you are with these kinds of things and how bad off the motor is. If your not comfortable with repairing this kind of thing don't bother with the rest of this.
I hate to replace anything that may be repairable. Unfortunately my friends know this and recently one asked me to look at his NuTone bathroom vent motor before he replaced it.
For the cost in time of an hour I was able to refurbished it.
A good way to check if it's a candidate for repair is to check how much play is in between the shaft and bushings. If you can feel movement then it's best to go ahead and replace it. If the problem is that the shaft is tight and just hard to turn then it may just need some cleaning and fresh lubrication.
The steps are simple. Once you have the motor removed from the vent cage you will see a pair of nuts and bolts holding two brackets in place. These brackets(one on either side of the coil) are what hold the shaft centered and house the bushings. Remove the bolts and the brackets. Be careful not to lose any of the washers on the shaft. These are spacers and need to be replace the same way they went on if they come off. All you need to do is clean both ends of the shaft put a little oil on the shaft and in the bushing and put it back together. If the motor has a plug and not just bare wires for reconnecting to the power supply then it's safe to just plug it in to any outlet for testing after you remount it in the vent cage. You will know right away if you were successful.
Hope this helps.
Oct 15, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
NuTone 9093 Heat-A-Ventlite: Ventilation not working
My guess it will be the motor.That would be the first thing I would do is replace it.
Mar 13, 2009 | Broan-NuTone N-9093CH Combination Heater...
Loose blower wheel assembly
place the push nut below the blower wheel. Don't bother with the top. The centripetal force tends to push the wheel down. The push nut in this position will prevent this.
May 05, 2008 | Broan-NuTone N-8663RP Combination Light...
QT 100L replacement
Don't worry, you can purchase just the fan from amazon (not entire motor). here: NuTone 0696B000 Motor Assembly for QT100 and QT110 Series Fans. I hope this was helpful. cheers
Oct 12, 2007 | Broan-NuTone QT100L Fan
Heating & Cooling Logo
179 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
