Question about Zenith Data Systems Zenith (OP-260-74501) Plug-In Module 24x CD-ROM Drive
DVD drive Stuck
I cannot open or my dvd drive. When the computer starts it opens and stays open, once I close it, it will not open. Any help?
Shove a paperclip in the hole in the front.
if that does not work, replace it.
Posted on Dec 29, 2007
  • 56 Answers
There is an issue with the drive.If u see in the front there is a small hole in which you can insurt and safety pin to oen it.Incase that is not working as well i would suggest to replace it.
Posted on Dec 27, 2007
Open stuck cd drive
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computerOpen My Computer and check to see if your CD or DVD drives have returned.
You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Oct 27, 2013 | Computers & Internet
My dvd does not play in laptop due to digital copyright problem. what can i do to fix this? no dvd wil play
Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Jan 28, 2013 | Compaq Computers & Internet
My dvd wont play on laptop
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Acer aspire dvd wont open with eject button
Whether you use your DVD drive to install software, make backups of your personal files or watch movies, having that drive onboard makes your computer more useful and more versatile.
While DVD drives function normally most of the time, sometimes a DVD will become stuck in the drive, and the tray will refuse to open.
Knowing what steps to take to resolve the situation allows you to start enjoying the advantages of the DVD drive again.
Log on to your computer and click the "Start" button. Choose "Shut down" from the menu and then choose "Restart." Wait for the computer to restart, then press the eject button repeatedly.
Remove the DVD if the drive pops out.
Since there is no hole skip this and go to cleaning the lens.
Shine a flashlight on the DVD tray and locate the small hole near the eject button.
This is the bypass hole and it allows you to eject a DVD when it becomes stuck.
Insert an unbent paper clip into the hole and push it in until you hear the DVD begin to spin. Push the paper clip in until the drive pops out.
Remove the DVD and insert another one.
Use the bypass hole again if the new DVD becomes stuck.
If the new DVD sticks as well, you need to clean the laser lens on the DVD drive.
Insert a laser lens cleaning DVD and close the tray.
Run the laser lens cleaning program at least three or four times to make sure the lens receives a thorough cleaning.
Restart your computer and insert a DVD to test the unit.
Oct 19, 2012 | Lifetime Acer Aspire 4810TZ-4011...
My drawer on my laptop will open but my cd is still stuck
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
if there is a small hole on the panel of your dvd drive push a staightened paper clip inside until you feel it press down this will open up the drive
if still no luck
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
May 27, 2012 | Computers & Internet
I press on CD button, but drive won't open. Acts like there is a CD stuck in it.
with a help of pin press in the hole provided just near to the eject button. CD tray will open immediately.
Feb 27, 2011 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
My dvd disk drive will not open anymore. The light on the side does not turn on either. When I try to poke the hole on the side the drive doesn't open. It seems it is stuck shut. Is there any way to open...
make sure that the dvd drive is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 30, 2011 | ASUS Computers & Internet
Dvd door keeps opening. Won't load dvd. Won't stay closed.Compaq laptop. Bought at Wal Mart this summer. Problem started a few weeks ago. Aaaaargh.
Check and make sure a disk is not stuck in the disk drive. If a disk is not stuck try closing the door and hold the door close, shut down the computer. Start the computer and hold the the door while the computer reboots. Hope this fixes it. djmax1966@yahoo.com..
Nov 08, 2009 | HP Compaq Presario R4000 Notebook
DVD Drive door will not always open. No obstructions. DVD Drive light flashes, but door will not open. Is ther some software conflict?
The door drive motor may be frozen.
  1. Shut down the computer and unplug it.
  2. Open the computer casing to access the DVD drive from inside.
  3. Disconnect the cable on the DVD drive leaving only the power supply connected to it.
  4. Turn on the computer.
  5. Push the OPEN/CLOSE button on the DVD drive. If it does not open, the drive is broken or the door drive motor is defective. If it opens, push the button repeatedly to open and close the door repeatedly to release any frozen part.
  6. If the door does not stuck anymore, shut down the computer.
  7. Reconnect the cable and turn on the computer.
Oct 30, 2009 | Sony Computers & Internet
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Computers & Internet Logo
75 people viewed this question
Top Zenith Data Systems Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Zenith Data Systems Computer and Internet Expert? Answer questions, earn points and help others
