Question about Poulan Garden
Feather lite weedeater disconnected shaft and
Feather lite weedeater disconnected shaft and reconnected and trimmer head wont spin
  • 437 Answers
You may not have the drive shaft seated all the way into the power head.
You will have to loosen up the drive shaft and push the shaft in but at the same time turning the trim head to fit it into the drive area, then tighten it back down.
Posted on Oct 03, 2009
  • Joyce Adams
    Joyce Adams Oct 16, 2015
    what do you mean by loosen up the drive shaft? when you slide the trimmer head onto the shaft there is only one way to slide it and it is marked,it has no threads and i think you are right it doesn't go all the way end for some reason,because when started it turns,but ejects off when you try to cut with it
Head won't spin on my feather lite weedeater
clutch is no good or flex shaft is broken.
Aug 06, 2017 | Weedeater Garden
Trimmer head won't stay on
Use a piece of trimmer like in head. As you slide it on it will likely be tight and hard to come off
Oct 13, 2015 | Poulan/Weed Eater No. Te475 952711797 17"...
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Stihl fs44 weedeater wont fire
Do you have compression, a good spark and is fuel going into the cylinder.? Working on a solution.
Jul 27, 2012 | Stihl Garden
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Weedeater starts fine but the string head will not spin. I removed the string head, and the shaft it connects to is not spinning either.
The shaft cable has either come loose at the head, or is broken at the engine most likely. Is this a 2 piece unit? If so, see if the cable turns with the grass trimmer section removed. If so, it is usually easiest to just replace the trimmer shaft section. One piece units require disassembly at the engine, and if you are not mechanically inclined, that can be a pain.
Apr 15, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
The head on my troybuilt weedeater TB70SS stopped spinning at higher RPMs. It will spin at real low RPMs. Help please?
if it is cable driven, if the shaft is curved it a cable , the cable is broken.
if it is a straight shaft with a gear box the gears are probably stripped
Nov 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
The trimmer head will not spin under power
The drive shaft is not set all the way into position. You will have to take the front casing off, as well as the lower part of the shaft, and work it into position that way. You may have to play with it a little bit.
Jim
May 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
611 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
