Question about Wharfedale DVD-M3 DVD Player
I keep getting no signal and an error code e-1500
  • 6,784 Answers
HI. The signal board has failed. This is an integrate part of the internal main assembly that regulates the input that the many decoder receives, via input cables(hdmi,rgb,s-video),ect... Due to the integrated status of the main board, The entire assembly will need ot be replaced. Contact your local retail depot for instructions on how to start a repair ticket for your unit. the only option here is to send it in for this repair. The actual parts needed are not available for consumer purchase.
Posted on Oct 03, 2009
Testimonial: "thanks i have only had it a few days so hopefully i will get a replacement thanks again martin page"
Where is my speed sensor for my 2007 silverado 1500
code p 0700 refers to transmission control system/MIL---malfunction==== causes --TCM---wiring
check all connections and wiring condition or replace the TCM
code p 0717 refers to turbine shaft speed (TSS) sensor ---no signal====causes ---wiring---TSS sensor---ECM/TCM
logically the TSS reports to the TCM to facilitate ratio changes so if the wiring , connections etc are not good then one will affect the other
Take it to an accredited auto transmission specialist shop, have it properly diagnosed and a quote
do not confuse a TSS with a VSS sensor as they are two different speed sensors in the same box
Sep 22, 2016 | 2007 Chevrolet Silverado 1500 2WD
How to repair a check engine on a 2005 dodge ram 1500
When "cjeck engine" light turn on, means that some fault code is stored in the PCM (computer) you will need scaner the PCM to know exactly what code is there; sometimes Autozone or AutoShop with scanner reader make this job for free. With this code number we could send additional details to diagnostic and solutions.
Keep us updated.
Jun 09, 2011 | 2005 Dodge Ram 1500
I keep getting a low temp error code PO128 on my 2004 Ram 1500 I changed the thermostat & that was not it...What should I change next? Fan Clutch or temp sensor?
replace next?? your boy racer weekend mechanic scanner ,its leading you up the garden path ,if vehicle works ok leave it alone
Jan 18, 2010 | 1997 Dodge Ram 1500 Club Cab
Cd keeps ejecting on pioneer 1500 error code 10
The manual says a code 10 is Electrical or mechanical. The say the solution is to turn the ignition on and off, or switch to a different source, then back to cd player.
Dec 10, 2009 | Pioneer DEH-1500 CD Player
Error 95-744 on DSR1500 AP sony
Main code 95 : Digital signal process system error and communication error with ICs
7 : STANDBY-OFF mode
4 : Capstan motor/FG
4 : FG cannot be detected.
Nov 07, 2009 | Sony DSR-1500 Mini DV VCR
Error c-6 keeps appearing
codes that start with c6 are caused by a problem in the heater. blown thermal fuse,
or bad heater lamp. you can access from the rear of the machine
Jul 15, 2009 | Copystar CS-1500 Copier
LEFT TRAILER TURN SIGNAL DOES NOT WORK
I'd get a 12vdc test light if you don't have one already & start from plug, and keep probing back from there. It may be as simple as a bad connection under truck where joined into harness.
Nov 29, 2008 | 2000 Dodge Ram 1500 Truck
I have a sonny ericsson w810i,i use it text online with yahoo messenger and now and again i keep getting .sorry the requested item could not be loaded(status code 502,503)what is this please can you...
That is the equivalent of "page cannot be displayed" on the regular web. Or page loaded with some errors.
Yahoo messenger utilizes the mobil web, so if you have low signal, or a blink in signal, or if you are traveling and hand off between cell sites, you may get that error. As long as it is only occassionaly, I wouldn't worry too much about it.
If you do tend to get it frequently, keep an eye on your signal strength where you are experiencing those errors.
Aug 01, 2008 | Sony Ericsson Cell Phones
Error code of ricoh af1053SC 321.322. 326
To my knowledge below error codes refer to:
1. 321 - No Laser Writing Signal (F-Gate)
Error-1 Transfer Belt Signal Error
2. 322 - 1st Laser Synchronization Signal Error
3. 326 - 2nd Laser Synchronization Error
G Gate 2 Error
This would be a possible Laser failure or the transfer belt and would require service confirmation and possibly replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 04, 2008 | Office Equipment & Supplies
Wharfedale DVD-M3 DVD Player Logo
335 people viewed this question
Top Wharfedale Televison & Video Experts
Gareth Cockram
Gareth Cockram
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
