Question about Microwave Ovens
Sometimes when I turn on the broil Frist - the select knob to broil (left side) Second - the temp knob all the way up I smell gas and discover the burner is not ignited Turn both knobs off and repeat the process sometimes works, however, I'm always afreid to blowup the kitchen
  • 10,865 Answers
You have either a gummed up ignitor or a gummed up burner. Get a flashlight and take a close look at all of the components involved. Any part that is grimey will have to be carefully cleaned with a degreaser, then dryed thoroughly. If everything is clean, consider changing the ignitor.
Posted on Oct 03, 2009
Need to replaced bake broil switch,how do i get to it
Make sure you turn the power off, then remove the knob and there should be two screws that hold the switch in place, remove them. Then pull the stove out and remove the screws on the back panel and that should give you access to the switch
Apr 15, 2015 | Microwave Ovens
What to do when oven smells like burning plastic
new ovens do have a certian amount of "burn in" to do when there new best to heat up and cool off oven several times before actuall food use to remove any construction solvents and "cure" all the materials inside
also ck to make sure you removed all the shipping packing sometimes this gets left inside by accedent and smells something horrible when heated ( caution :: Foam degrades to cyanide deadly gas when heated!!!!)
Sep 08, 2014 | Microwave Ovens
Hi, I have a Maytag super capacity plus free standing stove. I think the past owners refitted it for propane. However, when I use the oven I can hear it turning off and on with the propane. Also, I smell...
My advice is to get a professional person to check this out. If you smell propane then there has to be a leak of gas. It could kill you if you don't get it repaired right way. Large flames mean you may have the wrong orifices in it.
Jun 22, 2017 | Microwave Ovens
How do I tighten the Timer Knob on my Whirlpool AVM 950 Microwave Cooker Hood Combo?
Look to see if a flat nut under the knob or a Allen nut/bolt that secures the knob is loose--some are drilled into the side of the knob.
Jun 14, 2012 | Microwave Ovens
All i know about my self cleaning oven is that it is a frigidaire. it was here when i moved in. i want to use the self cleaner but i have no idea how. nothing on it is digital. its all knobs. i have no...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 09, 2011 | Frigidaire Microwave Ovens
I have a CGR3740ADW EVERYTHING WORKS BUT TGE OVEN WONT HEAT I PUT IT TO A TEMPETURE AND ITS SAYS ITS PREHAETING BUT DOESNT HEAT OR SMELLS GAS THE BROIL WORKS FINE
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 08, 2011 | Microwave Ovens
My old GE oven (JSP38G052BG) won't bake or broil. It start then stop after 1 or 2 minutes. The heating elements get worm. Can you help me please
Hello ediben11.
If your oven's bake or the broiler heating elements won't heat but the range burners still work;the clock may be set for a timed or self-cleaning cycle. So,make sure to check the clock buttons and the knobs are set properly.
*If your clock has a knob that says "push for manual" then push the knob in after that, try the baking and broiling elements again.
*If it still does not work properly, you may have a defect in the thermostat/selector switch/common wiring.
*If the oven does not have a separate bake or broil selector switch; then the thermostat is probably the problem. It is not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Hope this helps.
Mar 23, 2010 | LG LMVM1945 Microwave Oven
Power level
Hi cindeet,
I don't have this particular model, but have experience with other GE stoves & ovens. Looking at the control panel for an Advantium 120 at the link below,
http://www.geappliances.com/products/introductions/advantium/downloads/advantium_brochure.pdf
I'd start by pressing the "Power/Temp" button, and then turn the knob to select which power level.
There is also a Help menu shown (upper left corner of the photo I'm looking at - page 4 of the PDF document referenced above.
Let me know how this works for you - thanks in-advance.
Jon
Dec 23, 2008 | GE Advantium 120 Convection/Microwave Oven
How do i adjust the power level?
Hi Cindeet,
(I just responded, but it doesn't show-up - - my apologies if this comes thru twice).
Looking at the brochure at
on page 4, there's a control panel with the "Power/Temp" button - try pressing this, then using the knob to select the power level you want.
There's also a "Help" function - - upper right-hand side of the control panel.
Let me know how this worked for you - thanks in-advance.
Jon
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
