PC fans turn on but it doesnt do anything else
I live in a place where electricity comes and goes very often and the only protection i have for the pc is a power voltage stabilizer device. Now, when i try to turn on my shuttle xpc all i get is the fans turning on and nothing else. I get the blue light but no orange light from the hard drive. What can I do??
  • 3,940 Answers
Most likely the power supply has failed. Remove any PCI expansion card, disconnect power to all drives, all external connections except video, see if the system posts. If you still get no video and just a power light indication, then I'd replace the power supply (Issue will be power supply or Motherboard at this point)
If the system does post, then power off and re-connect items one by one until you find the faulty part and replace it
Posted on Oct 03, 2009
    President:
  • 2,049 Answers
It is likely that the on & off of power surges and loss corrupted the boot sector on your harddisk.
Try changing the boot order in your system BIOS to make the CD/DVD drive the first bootable drive. If you aren't familiar with changing the BIOS settings, see this article...http://www.wikihow.com/Change-Computer-BIOS-Settings and tab over to the boot settings. Once you're done, insert a Windows CD and see if the computer boots up .If it does, it indicates a bad harddrive.
  • 6,784 Answers
HI. check the hard drive pin plug that connects to the main power supply unit. make sure it is connected properly. if the connections are correct, this will confirm that the motherboard has failed.
My compaq 610 wont start up. went i connect de charger the powerbutton lights goes on en off.
When the power button blinks do you hear the laptop fans run on full speed? If that happens its because your laptop is overheating and is trying to cool down. It will not turn on until it cools down to protect from damage due to heat.
Use your laptop on a hard surface and dont block its vents with anything. If you want to use it on bed keep it on a laptop cooler or a thick book to allow ventilation.
If laptop doesnt turn on at all, the motherboard might be damaged. Take it to repair shop and check whats wrong.
Nov 01, 2013 | Compaq Evo N610C Notebook
When i turn on laptop it goes to a screem that comes up that says there a problem and hit r to repair but doesnt do anything
Put the Windows CD (assuming it's Windows and the PC come with a CD) in the drive, reboot/restart and see if that doesn't give better options.
Feb 24, 2010 | Dell Inspiron 2200 Notebook
Computer turns on leaves message and cuts off
this means that your cpu fan is facing some problems so its better change it or else your pc will encountered on and off. you can use it for 2-5 minutes then turned off automatically and you will notice the the lights is still on.
Oct 07, 2009 | HP M490N PC Desktop
My sony goes out and then there comes 'protected' on the display
Sounds like its over-heating.
Two things:
1. Unplug and flip upside down and use canned or compressed air and clean it out. Remove chasis if necessary, BUT, do not touch anything with your hands!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! The capacitors inside will hold LLLAAARRRGGGEEE amounts of electricity and can electricute you even while unplugged from an outlet. Just spray it out with the air
If that doesn't work....
2. Place a fan on top of the unit or on the vents. Do your best do keep the device WELL VENTILATED and COOL!
Air flow is key to lifespan of amps.
Oct 01, 2009 | Sony STR-DE405
Invalid copyright protection
yeah but the programs are costly. you need ANYKEY, ANYDVD, SCSS PROTECTION FREE, and CLONE-DVD(which also rips xbox and ps3 games) to be able to do this for free.
Jul 19, 2009 | Video Game Consoles & Games
PC will not boot
Your power supply is not woring properly, the short whistling sound was from the fan of your power supply. Maybe its too dirty, try to clean it well and place it back. Maybe it might help you..
Jun 22, 2009 | Computers & Internet
How to remove bathroom fan pull switch?it doesnt click
1 turn power off remove appropriate fuse
2 UNSCREW PROTECTIVE CAP
3 screws aqre visible they usually hold 3 wires
black green and red. if they have losts of black wound together it means they are in series with other lighyt switches. Ideally get an electrician in.
anyway unscrew the wires from their holders and attach a new swtch placing wires basck in the same congfig. RED is LIVE Black is RETURN ( Usually) and Green EARTH.
(Sometimes live and return may be blue and brown)
put cover back on replace fuse and turn power on and hope there is no "bang" because you put wires in wrong way
Jun 12, 2009 | Electrical Supplies
Windows protection error
boot it from your recovery disc or a proper bootable OS disk, and try repair mode. if this doesnt work, you will need to reinstall your OS
Mar 18, 2009 | HP Pavilion 6835 PC Desktop
Installing windows live messenger
It could be that either your virus protection, or a virus itself is inhibiting the installation from finishing. Try getting a Virus protection program like mcafee, and installing that and see if it works.
Apr 14, 2008 | Lenovo 3000 V100 Notebook
Oven fan
you dont fix it its working fine, the fan comes on at a predetermined temp and doesnt shut off unit l cools to a certain temp as well , its to protect electrical components from overheating. every new stove does it has to happen!!
Feb 01, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
