Question about InFocus ScreenPlay 4805 Multimedia Projector
My ScreenPlay 4800 does not seem to pick up any input from a source. I can get the ScreenPlay menus but no signal from any computer.
  • Anonymous Mar 20, 2014
    is a dell inspiron 15 (windows 8) compatible with the ScreenPlay 4800
  • 2,237 Answers
Reset the settings to factory default. if no change, make sure the resolutions match.
Posted on Oct 16, 2009
I got a Samsung 1080i television, but when i connect my dvd player to the back, it does not pick it up. i also tried connecting a tv freeway antenna and that did not work either.
Check the input selector. If it is not set to use the source signal type, the set won't pickuup any signal. If the source signal is antenna, you shoud select antenna as input selector. If the source signal is AV, you shoud select AV in the input selection. Press the input button at the remote controller, and do the needy.
May 31, 2017 | Samsung Televison & Video
'no signal input'
D-Sub is usually used for input from a computer, make sure the TV's input source is set to Analogue or Digital (or DTV) as it seems to be set to accept input from a computer, if you do not have a computer connected, then this is why it is complaining of no signal. It will not automatically defer to normal TV without being told to do so, have a look in the manual, or guess around the remote control to change the source of the signal.
Sep 14, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Locked in searching source
Click menu, go to the third screen, unclick source lock, and select the proper source, remember that the format need to be setup according to your output that's coming in to the projector. Under each source format there are sub menus for various input types as well.
Tony
Feb 09, 2013 | InFocus ScreenPlay 5700 Multimedia...
Need user manual screenplay 4800 projector
The reference guide is on this web site:
http://www.infocus.com/support/Products/Projectors/SP4800.aspx
Mar 27, 2010 | InFocus ScreenPlay 4800 Multimedia...
My Infocus Screenplay 7210 projector will not detect any input source. It continues to say searching... Any advice?
reset the settings to factory default. then select auto source. swap out the cables, and make sure the resolution matches.
Jan 01, 2010 | InFocus ScreenPlay 7210 Multimedia...
Sp4805 turns on by itself, direct tv picture will run for a short while then dorps out. I can't seem to pick a source? I tried my dvd player and it seemed to work normally. menu options are not highlighted...
In the sources menu where you assign sources, the second selection from the bottom is where you enable/disable sources which can inhibit a source/input from working even if it is assigned. Also check mark the auto source enable box.
If the input you are trying to use is not assigned or enabled many of the menu items are grayed out.
A quick fix is selecting the "factory reset" in the menu as the default factory settings are such that all input's are set to work.
Good Luck!
SagerTronics
Nov 13, 2009 | InFocus ScreenPlay 4805 Multimedia...
Infocus X1 picture freezes and dissapears and then comes on again
your display settings may be off, so change settings to factory reset and you may have to drop the resolution on your computer. you may also have a bad cable, so try a different cable.
Jul 03, 2009 | InFocus X1-RE Projector, Factory...
DV input to DV deck
it is a matte of TBC lack your editter don't produce tbc signals with the video out you need to install a tbc board while your old panasonic has built in tbc board regards please don't forget to rate ,thx
Mar 05, 2007 | Sony DHR-1000 DVHS VCR
InFocus ScreenPlay 4805 Multimedia Projector Logo
224 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
