Question about Pentax K100D Digital Camera
Pentax AF200S can damage my k100D camera - Pentax K100D Digital Camera
4 Suggested Answers
  • 18 Answers
SOURCE: Pentax K100D black spot on images
To clean the sensor on the K100D . . .
1) Turn the camera on.
2) Press the "Menu" button.
3) Press the right arrow to the "Set-up" tab.
4) Press the down arrow to the "Sensor Cleaning" item on list.
5) Press the right arrow & follow the on-screen instructions.
And don't touch the sensor with anything. (You will damage the sensor).
And don't blow on the sensor. (You will get your spit on the sensor).
I used one of those old rubber blow bulbs that people used to clean their lenses with before the Lens Pen came along.
Take care & Happing Imaging!
Glen
Posted on Jul 26, 2008
mail541
  • 58 Answers
SOURCE: Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Posted on Jan 21, 2009
micromaster
  • 3614 Answers
SOURCE: What Memory Cards will work?
Hi,,
Unfortunately, the Pentax K100D is not SDHC compatible, which means that the camera can be equipped with a maximum memory capacity of 2GB.
It is also advisable to choose a fast version of the Secure Digital memory card, such as Ultra II or Extreme III by SanDisk. I would recommend using a memory card of at least 512MB, or even 1GB if you can.
Hope this info helps
Posted on Dec 03, 2009
Testimonial: "Thanks for the quick response - glad I asked, or I would have paid for something that is unusable for my camera!"
Picture is not displaying on sony dsc-hx1
Talking about two camera's my guess is you made a picture with a Pentax K100D and you put it on the memory card in a Sony dsc-hx1.
In the manual the Sony tells what sizes of pictures it can display. None of the 4 sizes the Pentax K100D makes, is in that list.
Perhaps you don't mean this, please let me know.
Oct 29, 2013 | Pentax K100D Digital Camera
New Pentax K100D Super, shutter does not work. Av -- flashing 688 under battery sign. Replaced new batteries did not resolve problem
I suspect dirty contacts on either lens or body. Clean contacts. Should alleviate problem. This happened to my K100d.
Dec 11, 2010 | Pentax K100D Super Digital SLR Camera
Dropped my pentax k100d. Lense is fine, Camera says card locked, will not delete or fire shutter. Sent for repair, was told circuit board was damaged and quoted £306 for repair. Is it possible...
Your best bet is to try a local camera shop and have them fix it. Cameras are dangerous to disassemble yourself because of extremely high voltage electronics that can kill you if you touch the wrong parts. I had a K100D and it's circuits were also fried at one point, so I can sympathize with you. Try taking it to a local shop and seeing if they can beat Pentax's price. Odds are good they will try, but do not attempt this yourself. Even if you could find the parts (which you likely can't) then you will end up better off having it professionally fixed.
Nov 13, 2010 | Pentax K100D Digital Camera
Memory Card error message
The K100D works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot is is electronically incompatible.
Sep 25, 2009 | Pentax K100D Digital Camera
Pentax K100D super lens problem
Read the K100D manual. Go to the Setup menu and allow for lenses with manual aperture settings.
Aug 04, 2008 | Pentax 100-300mm f/4.5-5.6 SMCP-FA Zoom...
Bad USB conection?
I assume that you are using Win.XP,
- did you check; System Properties>Hardware>Device Manager
Is there anything like yellow exclamation etc, especially on the USB section?
- Is it BIOS USB function enabled? Maybe disabled by accidentally.
- You said nothing working through USB, all ports are same?
If this ocurred all of a sudden, than I think you have a software problem.
I have a K100d, its been seven months now and ~6500 photo. My USB cables&fittings are fine, I always using USB port to transfer photos, no problem at all.
I hope your problem will be solved in a short time.
Sincerely
-halotheracer-
Feb 05, 2008 | Pentax K100D Digital Camera
Achiever 260 AF for pentax
Check the voltage trigger of the flash, if you're under 7vdc. Then you are good to go.
atdlee@netzero.com
Jan 31, 2008 | Achiever 260AF for Nikon TTL Flash
Pentax K100D Digital Camera Logo
190 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
