Question about Sceptre X7GNAGAV 17" LCD Monitor
Sceptre X7G nagaVI problem
My monitor just randomly stopped working. whenever i turn it on now the indicator that shows its on just keeps flashing red and blue. can i fix this or do i have to buy a new monitor?
  • 4 more comments
  • Anonymous Dec 26, 2007
    Same thing happened to me. Just flashes red and blue. I have tried hooking up to different video source and switching power cable, no luck. Any other ideas?
  • Anonymous Jan 02, 2008
    MY SCEPTRE 17" LCD MONITOR TURNS ON AND 1 SEC LATER THE SCREEN IS BLACK I SHUT IT OFF TURN IT BACK ON AND DOES THE SAME THING CAN YOU HELP ME.. I UNPLUG AND REPLUG IN STILL DOES IT I TRIED ON FRIENDS PC AND DOES THESAME THING..
  • Hoopibaba Jan 07, 2008
    I have the exact same problem. Is there a reset or some sort of thing to get this thing going again?
    The monitor is barely a year old.
  • Greg Schmidt Feb 25, 2008
    Same problem. red,blue, etc.Have tried it on 3 computers.no go. hard to believe this pretty new monitor has failed. Hope there is a reset somewhere.
  • Tony08 Feb 28, 2008
    Add one more to the list. All it wants to do is flash the blue light when it's hooked up to the computer. I have also tried it on 3 computers.
  • Turnerd Mar 08, 2008
    same problem.. the blue power indicator just keeps flashing. When you first power it on it shows a text box in the middle of the screen then goes away, then the power light just flashes.
  • 472 Answers
For most of the problems above you will find it is bad capacitors on the power board sending unstable power accross to the controller board.
For the last posted problem (Comment by Guest, posted on Jan 02, 2008) you have a dodgy inverter circuit that needs to be repaired.
Both faults should be fairly cheap to have taken care of at your local TV repair shop. You may need to call a few in your area not just for a quote, but also to see if they are willing to work on an LCD monitor.
Hope that helps you all =)
Posted on Apr 11, 2008
I had this problem with my x7g. I unplugged the vga cable from the video card, and unplugged the power from the monitor. Then, I held down on the power button on the monitor while plugging the power cable back, and kept holding down for 5 seconds or so afterwards. I then turned on the monitor and plugged the VGA cable in. It now works!
Posted on May 03, 2008
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Cannot use the 5 push-bars on X7G-NagaV to reduce the pink (red in) the background. Do you have instructions for which button to push & the sequence? Thanks
Please check to make sure that the pins on both ends of the VGA cable are OK and seted properly on bothe ends.
There is no adjustment for color casting on the screen (redish, greenish, or bluish cast).
You may have problem in the monitor or the video card.
http://s807.photobucket.com/home/budm/allalbums
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
May 09, 2010 | Sceptre X7G-Naga 17" LCD Monitor
Order of the connectors on the X7G-NAGAVI?
OK, you will have four connectors (each one with pink and white wires), there are two set of the connectors, two are above the transformer, two below the transformer. The monitor uses four lamps, two for the top side of the screen, two for the bottom side of h screen. You can plug either one of the pair of the connector to the top group of the connector, same for the bottom group of the connectors.
May 05, 2010 | Sceptre 17" LCD Monitor
At start-up, Sceptre X7 monitor flashes on, then goes black. Must turn computer on and off numerous time before monitor will stay on. How can this be fixed?
Hi Friend,
You need to check your display setting in your computer..i mean to say..you need to click on desktop then properties then display then screen saver then change the time.....
Dec 20, 2009 | Sceptre X7G-Naga 17" LCD Monitor
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
Sceptre X7G-Naga VI
My problem sounds equivelant: The problem is that it will power down after 15 minutes, then take 1/2 hour or more to power back up!I believe I have solved my problem with my X7G! I remember seeing a direction on the only direction papaer I got with it that told me to Turn off ALL POWER SAVING WINDOWS SETTINGS! I think the monitor is set to care for all the monitor/power saving itself. I am going to try it and will get back to you, or just try it yourselfs!
CWD
Dec 22, 2008 | Sceptre 17" LCD Monitor
Sceptre monitor x7g-nagaVI
Problem is 2 Capacitors on the power inverter board, at 1000 uf 16 volt. This one was on the model xg7-naga V 17 inch monitor.
Jan 14, 2008 | Sceptre 17" LCD Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Sceptre X7GNAGAV 17" LCD Monitor Logo
4,700 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
