Question about Toshiba TLP-B2 Multimedia Projector
Toshiba TLP-B2 Ultra Lamp not lighting
The lamp flashes and then goes out, the indicators then after awhile go out. It is suppose to be a new lamp in it. What could cause this and what is the voltage to run the lamp?
thanks
  • 9 Answers
SOURCE: Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Posted on Jan 22, 2008
  • 9 Answers
SOURCE: Toshiba TDP-S20 lamp problem
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
SOURCE: Toshiba TDP S8 projector shuts down suddenly
most probably the lamp is dead already.
jimag2008
Posted on Jan 24, 2008
The Machine
  • 788 Answers
SOURCE: Toshiba TLP s30 projector identification part
This is what Tishiba indicates in the manual for your problem:
Lamp went out during use, or won’t come on
→ Returns to standby after about 2 minutes. If the projector fails to
operate normally after turning the power back on, either the lamp
needs replacing, or there is a problem with the projector.
• If a lamp burns out, replace it with a new one.
• Unplug the power cord, and contact your dealer.
Obviously you are at the contact your dealer part which isn't really a good situation since you are in Brazil. Researching parts will get back to you when I find something.
Posted on Mar 28, 2008
  • 7 Answers
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Posted on Apr 06, 2008
Toshiba tlp-b2 reset lamp timer
Product is not identified. Question is not clear.
Give more information.
Toshiba tlp-b2 appears to be a projector and not a timer.
1) Add a comment with clear description of timer and what timer controls for possible identification, and then say what you want to know.
2) Add a comment and include link to in-focus photo of timer posted on flickr for possible identification, and then say what you want to know.
Aug 09, 2011 | Hardware & Accessories
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP projector identifiation part
You need to check lamp again, it may be not well mounted.
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
Need a tdp t90a lamp driver module board where can i get one and price - in australia
I am having the same issue, Were you able to aquire a lamp driver module for your projector?
Dec 11, 2009 | Toshiba TLP-710, TLP-711, TLP-G5, TLP-G7...
Flashing Temp indicator light, after 5 min on a cool morning
Its a Low Coolant indication. Fill the reservoir to at least the MIN level.
Jun 02, 2009 | 2002 Volkswagen Cabrio
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
TLP-B2 projector lamp problem
my suggestion that unit is faulty and i recommend that you bring to the service center for repair that unit.
Jan 28, 2008 | Epson LCD PROJECTOR, XGA, 3500 ANSI, 1024...
Lamp
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
Toshiba TLP-B2 Multimedia Projector Logo
69 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
