Question about Bosch Saws
Cant change blade, holding stem is stuck - Bosch Saws
  • David Ford
    David Ford May 11, 2010
    for what model number and brand, let me know and I will find a print and see if I can help.
  • David Ford
    what is the exact model and brand and I will try and help.
  • 66 Answers
Holding steem, guess you are talking about the shaft that holds blade.
move the shaft down by squeezing the trigger.if shaft doesnt move you have a trigger problem or motor problem.
Posted on Nov 07, 2009
How do I find out if my Cuisinart blade has been recalled? Model #DLC-7E
The simplest way to check if the DLC-7E blade is one of the recalled blades is to take the blade out and look at it. If there are 4 rivets holding the blades to the stem, it should not be used. For more information, look at https://recall.cuisinart.com/ .
I hope this helps.
(The rivets, if present, will visible when you look at the top of the blade where the two sections of the blade go around the stem of the unit.)
Jan 16, 2017 | Cuisinart Food Processors
How do I get the kneeding blade out of the bread machine?
soak the paddle in soapy water overnight with enough water to keep the paddle submerged. The next day wiggle it back and forth while holding the litte ears underneathe the pan. Move it up and down too. If it still doesn't break free go to you tube and type "how to remove a stuck bread machine paddle" have your husband do that move, but don' use more than one jug of water because the TBR15 pan is thin and can bend. Be sure your husband uses hot pads to hold the pan edges so he doesn't hurt his fingers. If that method doesn't work you will have to live with a stuck paddle or order a new pan assembly and paddle and then always remember to remove to soak your paddle after baking and remove it from
the stem, clean, and store. Daryl,,, from breadmachineshelp.com
Feb 26, 2013 | Toastmaster TBR15 Bread Maker
Dont know how to change the battery in my callaway golf warbird watch
Thank you for contacting Fixya.
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
  • Pull out the stem, which releases the back on some watches.
  • Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Best regards. Jewel
    Aug 27, 2010 | Callaway Quartz Golf Watch
    Blade stuck in makita 4351 jig saw cant remove
    Take the set screw that holds the blade all the way out.
    Then take a ice pick or small flathead screewdriver and work the broken blade out.
    Oct 24, 2009 | Makita 4351FCT Barrel Grip Jig Saw with...
    Changing lens on oakley razor blades glasses
    Firstly, remove your nosepiece. Grab hold of the frame at one of the top corners with an index finger and thumb - use your other index finger and thumb to hold the lens, apply presure and gently pull apart. The notch will release. To mount your new lens, insert one notch into the frame and press the other notch into place. Do not apply pressure to the stems or hinge.
    Sep 04, 2009 | Oakley Crush OAK0333 Wrist Watch
    Am I missing a part
    I overlooked this too. Set into the foam packing material is a stem made just for the shredding disk. It's about 4" long and also has a hex shaft. This hex is just slightly smaller than the hex on the other shaft the drives the blades. The dough hook - Remove the blade assembly and put the dough hook in its place.
    Apr 08, 2009 | Black & Decker Food Processors
    How to attach Cuisinart blades DLC 8 to DLC7 stem
    The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
    -Tha Mp3 Doctor
    Jan 01, 2009 | Food Processors
    Saws Logo
    175 people viewed this question
    Top Bosch Saws Experts
    Parson's Repair...
    Parson's Repair...
    Jim London
    Jim London
    Are you a Bosch Saw Expert? Answer questions, earn points and help others
