Question about Frigidaire ATF6000ES Front Load Washer
Model #LTF 530 FSO will not drain and has the smell of burnt electrical
  • 6,784 Answers
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
NOTE-If the hoses and pump check out ok, this will confirm that there is a serious within the actual control sector(Timer module or control board). It should be replaced i this case.
Posted on Oct 03, 2009
Quiet wash 1 doesn't drain
the pump could be siezed or blocked. burnt rubber smell from the drive belt. look under the machine and try to turn the pump pulley
Apr 17, 2014 | Whirlpool WED5600XW - 27", 7.4 Cu Ft, He...
Rattling sound and burning smell
im not a dishwasher repair man but i know about mechanical and electrical equipment. sounds to me like a motor has burnt or burning out probably with one of the pumps. if its during wash then its the wash pump if during drain then the drain pump (im assuming these are two separate pumps)
Dec 20, 2012 | Hoover HED661280 Dishwasher
What is causing the bad electric smell from my dishwasher?
one or more components is burnt on the board of the unit. Or there might be a bridge of wire which is causing the smell....
Jan 05, 2012 | GE Dishwashers
Washing machine stopped spinning after several loads, and I smell a slight burning smell, won;t drain either.
it sounds like u might have some electrical problem in the controls however it may be the pump itsself has gone out but if u r getting an electrical smell could be causing the pump not to get power or the pump has burnt up causing the wires to get hot and start to melt myy bet is that the pump has gone out its not horribly bad to change out but kind of difficult for someone who isnt used to doing this kind of stuff
Feb 25, 2010 | Washing Machines
My dishwasher will not drain the water out.
Usually this is the drain solenoid. It's usually behind the lower cover. You may be able to smell an acrid (burnt electrical) smell when you take off the cover. The part isn't too hard to replace on most dishwashers, and shouldn't cost more than $20 or $30. MAKE SURE YOU TURN THE POWER OFF FIRST!!!
Aug 27, 2009 | Frigidaire Dishwashers
Dryer Wont Start - Smells Burnt
check for shorts and something holding the fan also look at breakers
Aug 11, 2009 | Whirlpool GEW9200L Electric Dryer
Burnt plastic smell that burns your nose
sounds like it could be electrical then... have you done any changes to the electrical at all? rewiring, changing headlights, etc? I had a similar smell when I changed my headlights... new headlights were defective and were melting the housing and harness...
Aug 11, 2009 | 1994 Chevrolet Camaro
Start button doesn't start the dryer
see if the drum is jammed if not replace the motor
Mar 31, 2009 | Dryers
Xbox has burnt electrical smell
my xbox power is 100v and i connected it to 200 v
waht shal i do
Apr 04, 2008 | Microsoft Xbox Console
Frigidaire ATF6000ES Front Load Washer Logo
212 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
