Question about Pioneer DEQ-9200 3-Band Car Equalizer
Wiring diagram for pioneer DEQ-9200 DSP - Pioneer DEQ-9200 3-Band Car Equalizer
Matteh
  • 83 Answers
SOURCE: confused between deq 7600 nd 9200
Probably DEQ 7600, XD
Posted on Nov 30, 2007
Sphynkter
  • 221 Answers
SOURCE: my pioneer deq-9200 equilizer keeps resetting to
The EQ has two power wires on the back like a head unit. One is constant power, and the other one is ignition/switched power. This normally happens when the installer takes the switched power and applies it to both power leads going into the EQ or head unit. The EQ needs the constant power line run to a 12V source that never turns off. The constant power line is normally yellow, and the switched power line is normally red.
Posted on May 19, 2009
SOURCE: DEQ 9200 does nothing but blink
Check DEQ "back up" battery wire (orange color), use multi meter to measure the voltage. If voltage are unstable then you must re-wiring the back up battery wire, link and loop it to your alpine player back up wire (yellow color). If it still same problem happening, then sent your "DEQ-9200 hide-away unit" to nearest Pioneer ASD. Change itside P.C.B. back up power battery (black color, 5.5volt -beside system control IC) and clean up the battery leaking part.
Posted on Jul 13, 2009
SOURCE: Need wireing diagram for pioneer deq 7600 4pin
I need to see a diagram how or how to setup my equalizer and reverb to my amp all pioneers old stuff sg60 and sg540
Posted on Jul 30, 2009
  • 21 Answers
SOURCE: I'm searching for a visual diagram to show the
go to crutchfield.com and type in your model.on the right side of the screen it lists whats in the box.from there you can print a diagram.
Posted on Sep 06, 2009
My head unit resets settings when key is taken out
Do you have the yellow wire going to a constant 12v power source? The yellow wire controls the memory of the radio and needs to have 12v going to it at all times, even when the key is taken out of the ignition.
Jun 28, 2012 | Pioneer DEQ-9200 3-Band Car Equalizer
Upon installing deq 9200....a humming sound exist as i pedal my gasoline
Check your ground wires. Power and audio need to be ran on opposite sides of the vehicle. Try re grounding the radio the a new location. make sure all grounds are connected to bare metal.
Feb 17, 2011 | Pioneer DEQ-9200 Universal Audio Processor
I have a deq-9200 one day it just shut off, I've tried everything, fuses , etc.i dismounted the central part (not the display) and noticed there was a liquid that leaked. Any suggestions?
Check the capacitors near the leak source if they vent ie swell on top then it is possible they have split causing fluid leakage they will not be far from leak on pcb replace the ones that look swelled
Jan 06, 2010 | Pioneer DEQ-9200 3-Band Car Equalizer
I have a Pioneer DEQ-9200 DSP Audio Processor
are your power wires and your rcas on oppsite sides this may be your problem
Oct 27, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I'm searching for a visual diagram to show the power hook up on the Pioneer DEQ 7600. I need a description of each wire and how to connect.
Sep 06, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
check your remote and ground source make sure remote power have enough ampirage for signal source that can cause it to blink
Jun 28, 2009 | Pioneer DEQ-9200 3-Band Car Equalizer
Need wireing diagram for pioneer deq 7600 4pin plug
Jun 28, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
My pioneer deq-9200 equilizer keeps resetting to default settings whenever i start my engine. What's going on here?
May 19, 2009 | Pioneer DEQ-9200 3-Band Car Equalizer
Pioneer 5.1 dolby surround multichannel processor ?s
You will need extra amp(s) to run 5.1 surround sound using out IP-Bus at the brain to in IP-Bus at the processor and rca output to the multi channels amp(s) and control the surround mode which is automatically activate by the format of the disc. The IP-Bus cables is colored polarized at each end to inter connect all components. Just hook them in series follow the color you may add all the components you have. You can also down load wiring diagrams at pioneerelectronics.com. Goodluck.
Apr 16, 2008 | Pioneer AVIC-N2 Car DVD Player
Pioneer DEQ-9200 3-Band Car Equalizer Logo
705 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
