Question about Refrigerators
I have a Maytage bottom drawer, refrigerator freezer. The bottom drawer freezer got noticeably warmer the day before yesterday. Having children, we chewed them out for probably leaving the drawer partially open. Now the freezer has stopped cooling, blowing luke warm/cool air. As expected, the upper refrigerator has stopped cooling as well since it gets its cooling air from the freezer. Was able to predict this after reading some of your posts fortunately saving most of the food. After apologizing to the children, I checked under the bottom and vacuumed the coils. Still not cooling. Every 4 or 5 minutes? I hear a soft humming/buzzing noise for approx 10 seconds from the back of the fridge. Compressor trying to start? Anyway it is not covered under the massive Whirlpool/Maytag recall of late. At least that I could find. Appears the fan is continually running as I feel the breeze in the back of the fridge at all times. What are the steps I need to do to investigate further? Any help is gratefully appreciated. Thanks, Joe in Nashville.
  • 220 Answers
First you want to make sure it's not under any sealed system warranty call Whirlpool who now owns Maytag if your not sure,but you should be able to find the warranty info in the users manual.
 Otherwise if it's out of warranty you can get it going with a 3in1 start relay from Supco,But you only want to do this if it is out of warranty.It comes with easy to install instructions and will get it going again they run about $20 you can also try the OEM relay/overload kit(you'll need your Model and Serial # to look them up)But more than likely you have a compressor that is going bad and the OEM parts won't start it they also run about $20.
 The 3in1 part has a start capacitor that gives the compressor a boost to get started and will usually buy you another year or two in which to decide if you want to repair this one at 5-600 dollars or look for another one.
You can find them online or at a local parts warehouse.
http://www.appliancepartscompany.com/xcart/product.php?productid=63475
Posted on Oct 03, 2009
Ge Monogram all in one refrigerator model zir36nmdlh is leaking and freezing food
There is a heater element that helps to defrost the coil, you may need to replace it.
May 04, 2014 | Home
Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
Sep 25, 2009 | Maytag MFD2560HES Bottom Freezer French...
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Lighting in freezer
there are two lights, one on the bottom of the freezer behind the second drawer up, under a plastic difuser
Jan 07, 2009 | Frigidaire FRS266ZDSB Side by Side...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cooling problem with a ge top freezer refrigerator
I have one that did the same. The coil in the back of the freezer was frosting up because it wasn't defrosting like it was supposed to. I noticed that the thermostat looked damaged so I ordered a new one from sears parts direct which by the way will show a diagram of the model you have. I just installed it last night so I will post how it comes out. This morning the freezer has a burnt smell but I am hoping its from the defrost not working for a while!
Mar 03, 2008 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
