Question about M-Audio Studiophile BX5 Main / Stereo Speaker
M-AUDIO BX5 wont't play music
My monitors(studio phile bx5) get no sound. The lights are on and if I touch the bass speaker I get a loud electric humming noise but no music, At first I thougt it was the input apparatus but I have hooked them up to several different components and the same problems persist.
Shuttle83
  • 1139 Answers
SOURCE: humming BX8
Hello docjgg,
This sounds like it may be a loose connection (ground) generation common mode noise or it may be a capacitor in the power supply going bad and not providing enough filtering of the AC voltage (allowing for 60 cycle hum). You should get a schematic for the speaker or just take some rule of thumb measurements of the power supply output, with an oscilloscope (you will be looking for ripple voltage, what you could do is use one of your good speakers as a comparison of good to bad.
If you do not want to work on this yourself, you could take the speaker to any TV repair shop or audio repair shop.
I hope this helps
Thank you,
Shuttle83
Posted on May 25, 2008
SOURCE: just hooked up my ashton home theater system up
You got scammed by the guys in a Van with a "Good Deal" LOL
http://www.scamshield.com/Feature.asp?id=1
http://www.ripoffreport.com/reports/0/404/RipOff0404098.htm
Posted on Apr 21, 2009
  • 44 Answers
SOURCE: M-Audio BX5 - No Power
Don't bin! This should be a simple fault to rectify.
Fault finding technique as follows:
Trace mains voltage up to main transformer - there could be a standby transformer with relay in parallel. Check mains voltage all the way until it stops. If you have voltage up to main transformer, check that you have low voltage at the other end - if not main transformer at fault. If you don't have, then check to see if you do have a standby transformer - much smaller and usually on small circuit board near where power comes in to speakers. They are notorious for blowing on many audio systems as they are constantly connected to mains unlike most of the other components - power spikes kill them in particular.
Posted on Jul 29, 2009
SOURCE: Hello. I have a
This is power problem, the cable might be ok but power might not be getting to the panel to power on the monitor, i will advice you give the monitor to a local repairer to help diagnose the panel on your monitor, the power diode on the panel might be bad or burnt, and will need replacement.
This is the best option since you are not electronically inclined.
Take care.
Posted on Sep 14, 2010
esound
  • 425 Answers
SOURCE: I'm a video editor (MAC
Hi, cases like that always comes u. Earlier you said just replaced it, that's not too good for anew monitor speaker.
You could test the fuse inside the speaker if it's still working, might be power fluctuation that might have caused it to blow.but you need to test it. If it is the fuse,fine! you can replace it, it does not cost much to replace.
Also if i can recall,most new stuffs always comes with guarantee with it,right?. I would suggest you could take it back and get a replacement, and i guess if they see it,since it is on guarantee,they can fix it for you without even charging you a penny.
Hope that helped.
Thanks and feel free to pass on your comment.
Thanks for using fixya..
Posted on Jan 12, 2011
I have a problem with my behringer b3031a truth studio monitors.Slightly before a sound it's played (and during the playing) they make a little buzz. Ex. I turn on Windows Media Player and as long as...
The fault is not with the speakers... It is with the noisy audio system common in computers. Get a decent USB audio interface and use balanced interconnect cables to solve the problem.
Aug 02, 2011 | Behringer B3031A 2-Way Active Studio...
Hi there, I have a pair of M audio BX5 speakers, one of them works fine, on the other hand, the other one sounds kindda funny. Both of the twitter and the 5-inch cone on it work, the main thing that's...
Little goes wrong with a speaker unless it has either been overloaded or subject to damp, extreme dust or has sustained physical damage from some sort of accident.
A rough test is to move the speaker cone gently through most of it's travel using an even pressure simultaneously on various places around the cone, I use my fingers.
It should move smoothly without any resistance and most importantly it should be completely silent through the largest or smallest movements.
If it sounds scratchy, the speech coil is either off-centre or it has suffered damp or dust and dirt has ingressed into the air gap or the chassis has become distorted.
If it is silent and electrically sound it should produce normal volume.
There was a time when loudspeaker repair, overhaul or adjustment was routine but these days it isn't economic except for the highest quality and replacement is best.
After gaining access to the interior wiring of the speaker cabinet I suggest further testing it by wiring it direct and leaving out the crossover if it has one.
Mar 23, 2017 | M-Audio Studiophile BX5 Main / Stereo...
When i play my bass through my amp it is really loud but when i go round my tutors for lessosns he has to turn his amp way up to get any sound at all.
His amp probably has lower gain. They vary quite a bit. Also the size of the speaker will affect it a bunch. If his is a tiny practice amp your bass will not generate much noise.
Mar 18, 2011 | Washburn Taurus T14 4-String Electric Bass...
I'm a video editor (MAC OSX). I playback audio at fairly low volume. Recently, I turned on my speakers (BX5) and only the R came on. L was dead and inspection revealed it was "blown". Can't...
Hope that helped.
Jan 12, 2011 | M-Audio BX5a Speaker
Hello. I have a pair of BX5 monitors, purchased in May 2003. Both have been working fine until a few weeks ago. One just stopped working. I have checked the cords and they OK. Power to the monitor is...
Take care.
Sep 14, 2010 | M-Audio Studiophile BX5 Main / Stereo...
Ac select REPAIR studiophile bx5
my speakdrs all of sudden started humming. Can't figure out what's wrong
Aug 19, 2010 | M-Audio Studiophile BX5 Main / Stereo...
Jul 29, 2009 | M-Audio Studiophile BX5 Main / Stereo...
Bx5a monitor speakers
Check the capacitor, if its swollen or rusty it needs replacing, also check the fuse.
Jun 22, 2009 | M-Audio Studiophile BX5 Main / Stereo...
CD SKIPS
well it depends on how you feel about opening your system. have you tried a cleaning cd? if not, then do that. If not, and u want to open it, then get some electronic cleaner spray (not sure how its called) and blow the laser clean. There are some resistors you can adjust, but thats getting very trick.
good luck
Dec 22, 2008 | Sony MHC-BX5 Shelf System
Speakers All Cut out Including Sub When Music is Played Loud
UNPLUG THE GREEN WIRE FROM THE COMPUTER AND PLUG IT INTO A CD PLAYER IF IT WORKS BETTER ON A CD PLAYER THAN THE COMPUTER IT SELF THERE MAYBE A PROBLEM WITH THE SOUND CARD AND ALSO TRY THESE STEPS I AM GOING TO GIVE YOU I AM SURE ONE OF THEM WILL WORK.
1. Please ensure that the all the connections between the satellite speakers and the subwoofer are firmly connected.
2. Next, please connect the green colored 3.5mm audio jack to another audio device such as an iPod or an MP3 player.
3. Ensure that the SoundTouch remote control is firmly connected to the back of the subwoofer.
4. Connect the power cord from the subwoofer and connect it to another single power outlet in your house. If you have an automated voltage regulator (AVR), please connect the power cord through the AVR instead of connecting it directly to a power outlet in your house.
5. Power up the speaker system and check whether the power button on the SoundTouch remote control will light up.
6. Turn on the Matrix Mode ON. This option is on the SoundTouch remote control. This is to ensure all speakers from the speaker system will produce audio that will be played from the audio device.
7. Play audio from the audio device. Check and see whether the all the speakers will produce audio being played from the audio device.
IF NONE WORK TRY THESE STEPS:
Jan 12, 2008 | Logitech Z-5300 Computer Speakers
M-Audio Studiophile BX5 Main / Stereo Speaker Logo
66 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Carlos L. Burgos
Carlos L. Burgos
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
