Question about Microsoft PowerPoint 2007 for PC
When I insert a movie only a black screen appears. When clicked the movie plays. How can I get the slide to appear like the begining of the movie?
  • 51 Answers
Install codec for your movies
download klite codec pack and install it than any movie will work fine
Posted on Oct 04, 2009
How can I add a .wav file to an entire PowerPoint slideshow? I only know how to add sound to a single slide and want the file to play through the entire presentation. Thanks in advance for your help.
Since you have not mention the power point version that you are currently using I give you the method to embed sound in your entire slide show for both PowerPoint 2003 and PowerPoint 2007.
Lets start with PowerPoint 2003 : Go to the slide where you want to initiate the sound track in .wav form.(1st slide is the default).
Go to Insert> Movies and Sound> Sound from file
Select your .wav sound file and click ok.
After you click OK you will se a dialogue box appearing asking you "How do you want the sound to play". You have to specify that. If you are not sure select "Automatically" so when you land on that slide during the slide show your music or sound will start automatically.
Select Slide Show ->Custom Animation to enter the Custom Animation pane. Confirm Your soundtrack is listed below in the pane.
  • In the drop-down list of the sound, choose Effect Options. Then the Play Sound interface appears. In the Effect tab, click the radio button beside Stop Playing After XXX slides (which indicates how many slides you want this song to play across) to enter the number of slides you intend to add. For example, you can enter a number from 1 to 999 for this field. Then the sound will play throughout the specified slides.
  • Next, check the settings in the Timing tab. To play automatically, you can set to Start After Previous with a 0-second delay. Click OK to exit the dialog box.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slide show if you don't want it appear.
Now your sound will play from the first slide till the last.
Life is much much easier with PowerPoint 2007
  • On the slide, click Insert to pick the Sound drop-down list on the very right below the tab. Select Sound from File in the list and choose the specified sound track from your hard drive.
  • Click OK and a message prompts, saying How do you want the sound to start in the slide show? Click Automatically.
  • Now click the sound icon to display the Options tab. Click on the tab, and set Play across slides for Play Sound.
At the moment, it is time for you to play the entire slide show while enjoying this pleasant sound score.
NOTE:
  • The sound you insert must be as long as your slide show. That is, if the slide show lasts 5 minutes, your soundtrack should also be at that length. Otherwise, the sound would be cut off until the slide show ends.
  • It is highly recommend that you take PowerPoint 2007 for your convenience.
Jul 17, 2010 | Microsoft Office 2000 Web Components Book...
How to insert video in the PowerPoint 2003?
Insert a movie and play it automatically
In PowerPoint 2003, you can run your movies full screen. This is a very excellent feature.
  • On the Insert menu, point to Movies and Sounds, and then click Movie from File.
  • Click the video you want to use and then click OK.
  • Tips: Always put the movie in the same folder as your PowerPoint presentation. If you later move the PowerPoint presentation to another computer, copy the movie too. Keeping your movie in the same folder as your presentation ensures the link will still work. However, you should always test the movie on a new machine just to be certain. Re-insert the movie, if necessary.
  • After you click OK, you' are promoted with a message asking how you want the movie to start in the slide show.
    I recommend choosing Automatically even if you want the movie to play when clicked- I will talk about how to set this part too. (If you choose when clicked you have to click the black box to start the movie. Because I don't like to show the black box on the slide, I do this a little differently.)
  • You should now have a small rectangle sitting on your slide.
  • Insert a movie using a file on your computer or in another location, such as a server.
  • The movie appears as a still frame on your slide.
  • The trick I use is to move that rectangle off the slide, so it is sitting next to it, but not on it. You can size it down if you like. Click the movie (that is, the rectangle) and then drag it off the slide.
    Play the movie full screen
  • Right-click the movie object (the small rectangle) and on the shortcut menu, click Edit Movie Object.
  • The Movie Options dialog box appears. Under Display Options, select the Zoom to full screen check box, and then click OK.
  • If you want your movie to play automatically when you advance to this slide, you can stop here.
Test this now to see how it workd by starting the slide show. (On the Slide Show menu, click View Show.) Advance to the slide with the movie, (best if you have the title of the movie on it). Within a couple of seconds, the movie starts to play full screen. When the movie finishes, you return to the same slide (but no unsightly box appears). Click to advance to your next slide.
Add an On Click effect to start the movie
If you prefer, you can click to start the movie. This requires one more step, setting an On Click animation effect.
1. On the Slide Show menu, click Custom Animation. The Custom Animation task pane appears on the right side of the PowerPoint window.
2. Click the movie object (the rectangle) to select it.
3. In the Custom Animation task pane, click Add Effect, point to Entrance and then click Appear.
You have added an On Click effect. The animation effect you added is the one with the Green star next to it and a gray rectangle around it. If it doesn't have a gray rectangle, click it to select it. Your Custom Animation task pane should look like the picture below (except with the name of your movie in the list).
4. The last step is to move that animation up to the top of the effects list.
To do this, make sure the animation effect is selected, and then click the Up Re-order arrow at the bottom of the Custom Animation task pane. Or simply click and drag the animation effect to the top of the effects list.
5. Your effects list should now look like this:
6. You are done. Test this to make sure it works by starting the slide show.
(On the Slide Show menu, click View Show.) When you advance to the slide with the movie, you should not see the movie. When you click the slide, the movie zooms to full screen and plays. When it finishes playing, you are returned to the same slide. Click to advance to the next slide.
Souce: How to insert a Movie (or video) into PowerPoint 2003?
Jul 06, 2010 | Microsoft Office Professional 2007 Full...
I made a powerpoint presentation with PP2003, first added 6 slides, then added another 20. When I add music to the presentation, the music stops at the 6th slide. HELP!
To make a sound continue through multiple or all slides, follow these steps:
  • Go to the slide where you want to begin your audio track (defaulted as the first slide), and select Insert -> Movies and Sounds -> Sound from File to insert the sound.
  • After you click OK, you can see a message pop up asking how you want the sound to start in slide shows. Click Automatically.
  • Select Slide Show ->Custom Animation to enter the Custom Animation pane. Your soundtrack is listed below in the pane.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slideshow if you don't want it appear.
Now you can play the soundtrack from the very beginning to the end of your slideshow.
Source:
http://www.dvd-ppt-slideshow.com/powerpoint-knowledge/sound-across-slides.html
Jan 16, 2010 | Microsoft PowerPoint 2003 Student &...
DVD movies not playing but CD-ROM games and CD's do?
With the disk inserted, 1) double-click on MyComputer, 2) right-click on the DVD, and select Auto Play from the resulting menu; a window will appear, 3) click on your favorite DVD playing software and 4) check the little box below to do the same every time you insert a movie (as it used to be).
Apr 15, 2009 | E-Machines eMachines Desktop PC
"Take charge of your movie" PowerPoint Microsoft Office Online
For the first problem, try to run the Office repair option. If that doe not work, you will have to reinstall Microsoft Office PowerPoint. For the Movie problem. When you insert a movie, you should see something like the following image.
default.aspx?assetid=za010720961033The first line represents the automatic start.
You can either have the movie start automatically or on a mouse click. That seems to be the option you have set. This icon won't be on the slide, it appears when you first insert the movie so you can make your selections. You can get more information at this link: http://office.microsoft.com/en-us/powerpoint/HA011729321033.aspx
If this does not help, make another post and let me know.
Mar 14, 2009 | Microsoft PowerPoint 2003 Student &...
Powerpoint video problem
Does the videos play well in Windows Media Player? If not, it deciates that there are not proper codec installed on your computer.Try to download and install some new codec from official: http://www.microsoft.com/windows/windowsmedia/forpros/format/codecdownload.aspx. Go for codec references at: http://www.codecguide.com/
If the video plays well, please try the following methods:
Method 1.
1. Put video files and the PowerPoint presentation in a same folder.
2. Re-insert these files to PowerPoint presentation.
Method 2.
Insert -> Hyperlink, choose the video file you want to insert, and then click ok. After do this, you can click the hyperlink to view the video when present the slide show.
Method 3.
 1. Display the slide you want to insert video.
 2. Click the View menu in the menu bar, and then choose Toolbars in its child menu, later Control Toolbox to let Control Toolbox displayed. Choose More Controls which seems like hammer.
 3. In the succeeding dialog box, choose Shockwave Flash Object. Your cursor will change into a cross-hair - draw a rectangle anywhere on screen
4. Right click the inserted Shockwave Flash control, and then click Properties.
5. Click the Movie property > type the full drive path in the value column (the blank cell next to Movie), including the file name (e.g. C:a.swf) or URL (e.g. http://www.a.com/b.swf)
6. To make the Flash play automatically when the slide is displayed, set the Playing property to True;
7. Finally close the Properties window and save your presentation.
Method 4.
Convert your PowerPoint presentation to Flash use some third party presentation tools, PowerPoint to Flash converter, for instance.
BTW, the link: http://www.playsforcertain.com/tutorial.htm may help you.
Nov 04, 2008 | HP VP6121 Multimedia Projector
DVD player won't work for Panasonic SC-HT680
la tarjeta de elcctricidad se me quemo y no encuentro respuesto
Oct 11, 2008 | Panasonic SC-HT680 System
Trouble viewing DVDs
I signed up for the "chat" and the problem was solved very quickly. Thank you - great service!
Oct 07, 2008 | Televison & Video
Black screen instead of DVD playback
try changing the dvd drive speed in the system configuration, it may be at standard, change it to fast
Jun 25, 2008 | Sony PlayStation 2 (PS2) Console
Microsoft PowerPoint 2007 for PC Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
