Same Problem after installing the new updates, my Zune had an error and froze. Now all i have is a black screen and cant even sync or go to Zune device home page...
    Sergeant:
  • 236 Answers
REINSTALL THE UPDATES AND TRY TO START THE PLAYER.
AND VISIT THE WEBSITE OF ZUNE. YOU MAY GET THE HELP.
Posted on Oct 03, 2009
How can i update zune hd
How to update your Zune player
Overview
If you haven't used your Zune player in a while, you might need to update it in order to get the latest features and improvements.
Steps to update
  1. On your computer, start the Zune software.
  2. Connect your Zune player to your computer by using the USB cable that was included with your player.
  3. If a newer version of the Zune firmware is available, you'll see a notice to update your player. You can also manually check for new player updates in the Zune software. Go to Settings (located at the top of the screen), Device (located in the upper-left corner), and then Update (located in the list at the left).
  4. If you receive a notice to update your player, follow the on-screen instructions. Important During the update process, don't disconnect your Zune player it until the update finishes. The update might take several minutes. During this time, your Zune player might restart several times.
Mar 31, 2015 | Microsoft Zune 30 Gb Digital Media Player...
Zune won't sync and now some songs will not play all they way through
Go for software update from the zune website it will help you.
Also ensure that the settings are not changed .
Sep 25, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
PC will not detect my zune.
Hera re some ideas: http://www.devicedriverfinder.com/blog/device-errors/how-to-fix-zune-device-errors
Hope it helps solve your problem in case it still exists.
Jules
May 27, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 4 gb Zune was charging and now it wont come back on!
I found this on the Zune technical support (if this does help, be sure to rate my solution please):
Your Zune device is not detected by your computer or the Zune software
View products that this article applies to.
SYMPTOMS
When you try to use Zune Software, you experience one or more of the following symptoms:
• The Zune device is not detected by the computer.
• The Zune device is not detected by Zune Software. In this case, when you pause on the device icon in the lower-left corner, you receive the following error message:
No Zune device connected
• If you restored the Zune device software, the following messages are displayed on the Zune device:
Connect Zune to your PC
On your PC, open the Zune software and restore the Zune device firmware
THINGS TO TRY
To resolve this issue, follow these steps:1. Update the Zune software on the computer. To do this, click settings, click software, click GENERAL, and then click CHECK FOR UPDATES.
If the issue is still not resolved, go to the next step.
2. Restart the Zune device.
To do this, follow these steps: a. Set the Hold switch to the unlocked position.
b. Press and hold the Back button as you press the top of the Zune pad.
When the Zune device begins to restart, release the buttons.
3. Disconnect the Zune device from the computer, restart the computer, and then reconnect the Zune device.
4. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
5. When you connect the Zune Sync Cable to the connector port of the Zune device, make sure that both ends of the sync cable click into position. Additionally, make sure that the sync cable is not connected to the device at an angle.
6. Connect only one Zune device at a time. If you already have a Zune device connected to the computer, any other Zune that you try to connect will not be detected by the Zune software. Disconnect any additional Zune devices, and then try to connect again.
7. If a full-screen battery image appears when you connect the device to the computer, you must let the device charge for several minutes before the device will start and be detected by the computer.
For more information about how to charge a Zune device, click the following article number to view the article in the Microsoft Knowledge Base:
927348 (http://support.microsoft.com/kb/927348/) How to charge the battery in your Zune device
8. If you are using Windows Vista, install the Cumulative update rollup for USB core components in Windows Vista software update. This update resolves some reliability issues in the USB core components in Windows Vista. You will achieve better reliability in various scenarios by installing this update.
For more information about this update, click the following article number to view the article in the Microsoft Knowledge Base:
941600 (http://support.microsoft.com/kb/941600/) Cumulative update rollup for USB core components in Windows Vista
If you are not using Windows Vista, or if the issue is still not resolved, go to the next step.
9. Examine Windows Device Manager. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
b. Click Device Manager. Zune should be listed under Portable Devices.
Note If the device was installed incorrectly, Zune may be listed together with a yellow exclamation mark (!). Or, it may be listed under Other devices as USB Device.
Double-click Zune, and then click the Driver tab. The current version of the driver that is installed should be 2.3.1035.0.
If Windows Device Manager indicates a device problem, or if the version of the driver that is installed is not the current version, you must update the driver. To do this, follow these steps: 1. Right-click Zune or USB Device, and then click Properties.
2. Click the Driver tab, and then click Update Driver.
3. Click Search automatically for updated driver software.
4. Click Install if you are prompted to do this.
5. After the driver installation is complete, click Close.
If Windows Device Manager found the drivers, click Close. If you want to locate the drivers manually, follow these steps:1. In the Zune Properties dialog box, click Update Driver.
2. Click Browse my computer for driver software.
3. Click Browse, locate the \Program Files\Zune\Drivers folder, and then click OK.
4. Click Next.
5. Click Install if you are prompted to do this.
6. After the driver installation is complete, click Close, and then click Close again.
10. Examine the computer for conflicts that involve the USB host controller or the root hub. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
c. Expand Universal Serial Bus controllers.
d. Verify that no errors appear in the list of USB devices. A yellow exclamation point or a red "X" next to a device indicates errors. If any errors appear, contact the manufacturer of your computer.
For more information about how to troubleshoot conflicts in Device Manager, click the following article number to view the article in the Microsoft Knowledge Base:
310126 (http://support.microsoft.com/kb/310126/) Troubleshooting device conflicts with Device Manager
11. Try using a different Zune Sync Cable.
Apr 10, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune stopped working and is not turning on or charging
all you have to do is let it go dead and then wait to hook back up to sync cable it will start charging again and function like normal
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune screen froze
http://forums.zune.net/403986/ShowPost.aspx check the zune forums for any updates. microsoft is looking for a solution. this happened to every 30g owner 12am/2am
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Error Code COOD2772
This stuff just recently started happening to a lot of us... My **** started acting up yesterday... First was giving me some sort of error telling me it cant access my zune please disconnect and try reconnecting........ Now I am getting the same error you guyz have been getting talking about reformating.... i am going to call tech support today EVEN though I know their lame solution will be just to reformat... I want a root cause for this stuff.. Probably was some sort of windows update ****
Sep 28, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune sync problems
Hey tybaylock,
If your Zune "locks up" while syncing to your computer, there are several different things that you may want to try.
First, I'd suggest making sure that you've got the latest firmware updates for your Zune and software updates for your computer. In some cases, updating programs (including Windows itself) can improve performance and may even eliminate recurring problems such as this.
Second, you may wish to check if the files you are attempting to sync have any errors. Normally the easiest way to check files is to play them using the Zune software while the Zune itself is still connected to your computer. If there are any problems with the file or it is damaged in any way, the software should encounter playback issues and may display an error message. Additionally, you can even check the Zune software itself after a failed sync. You should be able to do this by clicking on "Device" and then "Status." Then if you expand the "Not Added" section, you should be presented with more information why the files could not be added to your Zune.
If neither of these suggestions resolve the issue, you may want to check out the article below for more information. Microsoft appears to have some additional suggestions available in through their online support center on how to solve this problem, as well as step-by-step instructions when necessary.
http://support.microsoft.com/kb/940705
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 17, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune Froze, erased content, and wont sync with PC.
Yes. There are several solutions to this. Rather than retype them, you may want to check out the forums at www.zune.net or support.microsoft.com.
Most likely you'll have to remove the Zune software from the PC, re-install it, reset the Zune.... I think you get the picture.
May 20, 2008 | Microsoft Zune JS8-00001 Digital Media...
49 people viewed this question
 Grubhead
Grubhead
