Question about Sansui HDPDP4200 42 in. HD-Ready Plasma Television
PDP MONITOR THE VIDEO CONTROL BOARD GONE I CAN'T FOUND IT
  • Sansui Master
  • 19,396 Answers
You listed your PDP monitor under Sansui | HDPDP4200 LCD TV. That is not a PDP monitor.
Please let me know make and model of your monitor, and please include the model number printed on the tag at the back of the unit.
Many thanks.
Posted on Oct 03, 2009
I have a pioneer plasma display pdp-435pu and power cabel but there is no connection wier for cabel connection
This model, according to what I have found from Pioneer, does not contain a TV Tuner. It is a multimedia Television/Monitor.
Oct 11, 2011 | Pioneer PDP-4350HD 43 in. Plasma...
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Monitor gone black but shows self test not floating
Sounds as though the control unit has died. There are 3 parts to most monitors. The video processor board, power supply board and the HV/backlight board. You can replace the video processor board.
Make sure you leave the unit unplugged first and set for an hour. Usually no other fix then replace the board.
Apr 29, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
No display under 1024x768
I have the same problem with 800x600. I've found that by setting the refresh rate to 56 Hz, I can get the games to play. For instance Age-Of-Empires II only works with this method. My old monitor worked fine, and this works at 1280x1024.
Apr 22, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
My hd4208TIII-PDP WONT COME OUT OF STANDBY MODE
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, just press tv/video button to switch input source, let the tv in sleep mode.
Credit: User IMJR
Feb 28, 2009 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
No picture on Pioneer plasma
first of all check out the fuse that mostly get blowned out in this problems.if the fuse is perfect then it could be the faulty capacitor issue check out on the main board with the help of the multimeter and replace the faulty ones and it should work properly.
Dec 10, 2008 | Pioneer PureVision PDP-5030HD 50 in....
PDP5016H Akai Plasma TV
is the control board the one with the rca jacks on it,for sound and video input?if so email me at mesa1965@yahoo.com,i need one.
Oct 28, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Cable/ribbons
Which cable do you need, the one that goes from the video board to the main control board? Also the power cable clip can be found anywhere, its one of the most common clips.
If you just pulled the wire out of the plastic shroud, you can lift the leg that holds the wire in with a pin and shove it back in. If the wires broke, you can solder it back together or I probably have a replacement here.
Sep 05, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Dell 19" monitor screen turns blank
i had same problem, fault was traced using a multimeter set to diode measurement, i found that one of the high power switch transistors in the inverter side of the power board was short circuit (there are four in the same area sticking up from the board, not surface mounted). normally they should measure 450 ish but when they read 0-010 its gone, pulled it out of circuit and remeasured it, gone, replaced and fixed.
Sep 16, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
First post is misleading...sorry..not one pin bent bb.but none were bent (typo) sorry
It could be the monitors invertor board has gone bad. Call a local computer shop and tell them you need a new invertor board for your monitor and see what they say. Write me back and let me know.
Jun 25, 2007 | Wintergreen CMV CT-723A 17" LCD Monitor
Sansui HDPDP4200 42 in. HD-Ready Plasma Television Logo
73 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
