Question about Ovens
I'm getting an error message F2 and the broiler will not turn off. It came on bt itself while the bake was on!
  • Ovens Master
  • 2,605 Answers
F2 on most jenn-air ranges/wall ovens indicates a fault in the oven sensor or relay board. I'd first check the sensor, (part # 12001655) it should ohm out at approx. 1100ohm @ room temp. If it is OK, it's probably a faulty "broil" relay and suggest replacing the power relay board.
The board (usually seperate from the clock and just behind it), on earlier model jenn-air/magic chef/norge/maytag etc. where known to burn up. part # VO4100260. double check those numbers with your model number at your local parts depot or service provider, those are just the most common for maytag built units.
hope that helps,
good luck
Posted on Oct 03, 2009
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Oven top element gets SUPER hot without warning
the sensor in your oven is picking up the high heat and posting error message which displays F2 ,at least the sensor is working but lets look at the problem isuspect one of two the first is your control switch needs tested i would say this is the problem and number two the elemant could be on its way out either of these problems are going to need a electrican to fix ,sorry i cant give you a simple answer to your problem.adrian
Jan 24, 2009 | GE Profile JTP18 Electric Single Oven
What is F2?
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board. F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Nov 16, 2008 | Jenn-Air Ovens
Broiler element not working
It's either the switch that supplys power to the broiler element or it's the element itself (probably the element itself). I'd go after that first as it's not that expensive.
It's not a thermostat because if it was, the bake element wouldn't work either. The broiler element is not supposed to come on except when in the broil mode or cleaning mode.
Mar 13, 2008 | Amana AOES3030 Electric Single Oven
Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Apr 10, 2007 | Jenn-Air JJW8527C Expressions Collection...
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
Ovens Logo
307 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
