Question about HP Office Equipment & Supplies
My HP Officejet J6480 all-in-one gives me Cartridge error: Cartridge on right must be replaced. I have changed the cartridge but still get the message.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
These types of 'severe' cartridge errors/alert messages (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges): http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
Posted on Apr 14, 2013
Cogz
  • 1326 Answers
SOURCE: Remove and check cartridge on right
How old is the printer? If it is over 2 years, buy a new one. It is not really worth have a service rep. come out and charge you $95 - $150.00 to look at. When you can buy a new one for $60.00. Unless, you have a special bond with the printer. It's up to you
Posted on Feb 08, 2009
M2Tech1
  • 313 Answers
SOURCE: canon mpc 200 error message ''wrong cartridge'', won't print
if you have the old cartridge still check the connection to see if it is the same as you had and check to see if you have an original or compatible cartridge as some wont be recognised.if there is an electrical connection board in it see if you can change it onto the new one
Posted on Jul 31, 2009
xptareq2000
  • 1447 Answers
SOURCE: The install cartridge message won't go away
yes it is problem your copier machanical problem.if it is original cartridge this printer or cartridge problem
Posted on Aug 17, 2009
xptareq2000
  • 1447 Answers
SOURCE: The install cartridge error message appears even
Dear sir
it is problem your printer machanical
please missing your right side spring lock is messing
  • 118 Answers
SOURCE: Changing toner cartridge on copier
Open up the large front door, it will swing downwards. At the top section you'll see four boxes with front handles. Each of the boxes is a slide-out container of toner.
Follow the instructions on the new toner box to prepare it for the copier.
You'll note each toner box has a color designation (on a plastic label just above where you grab). Simply grab the handle on the one you need to replace, pull it out and then slide in a new one.
Also note there are four colors: Yellow, Magenta, Cyan and Black. The LCD screen should indicate which toner bottle(s) to replace.
Posted on Aug 31, 2009
Hp officejet j6480 cartridge error problems
This type of fatal cartridge error (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. However, our test group has also seen these failures with brand new cartridges. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below on how to access respective printer's service menu and correct:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges):http://www.youtube.com/watch?v=8fE-IM4AVMc
Jan 12, 2012 | HP Officejet 5610 All-In-One InkJet...
My printer Model no. 4355 officejet gives an error name Cartridge Error refer to device documentation to troublrshoot. Plz tell me what can i do?
Cartridge error means the total failure of a print cartridge. Purchase a new one and replace, it will start working.
Oct 08, 2010 | HP Officejet 4355 All-In-One InkJet...
My HP J6480 printer will not recognize the ink level on a new Officemax ink cartridge. printer keeps indicating that the ink cartridge needs replacing.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 17, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge error hp officejet j6480 generic cartridge
I own one of these printers and refill cartridges for a living. When you get this problem its best to return the cartridge for another, thats what I do for my customers.
When buying re-manufactured cartridges its best to buy from a local store and ask about there return policy before making your first purchase.
If you are buying from a reputable re-manufacturer then this will be a very rare problem. It happens with genuine HPs too.
BTW this printer uses HP 74 & 75 inks. when buying re-manufactured buy the HP 74xl which gives (according to HP) 750 printers compared to 200 from the HP74. Remanufactured HP75s are fill to HP75xl capacity.
Sep 21, 2009 | HP Office Equipment & Supplies
HP Officejet J6480 ink level control
Your printer is the genune hp printer. It will not show the ink level of refilled and non-HP cartridges. Try the original one the problem will get rectified.
Apr 08, 2009 | Digital Products Hewlett Packard OfficeJet...
Cartridge error
try to put off the cartridge and then turn off the printer. Rest it for 15 minutes, then turn it on put the cartridge back again. If still didn't work out if you have spare cartridges try replacing it. Okay...
Dec 14, 2008 | HP Officejet 4315 All-in-One Printer
HP officejet 6110 all in one
Probably one of two causes:
1)Cartidge is Faulty/Out of Date/Not original.
2)Printer is Faulty.
Most HP cartridges have a specific life, no matter if you use it or not. You should check the cartridge life - its printed on the cartridge itself. If its in date and broken you can get a free replacement from HP. Try a new cartridge first.
If you are still getting an error message after changing the cartridge and your printer is no longer in warranty, its normally cheaper to throw it away than get it fixed. If its in warranty, call HP. They normally replace very quickly.
Sep 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
268 people viewed this question
Seeker5211
Seeker5211
