Question about Garden
How do I fix the pull cord on my honda small engine?
    President:
  • 1,776 Answers
Check out the video at the following link and see if it is of assistance in replacing the pull cord on your mower. Hope so and best wishes.
http://www.youtube.com/watch?v=i3ZMVFi0yqY
Posted on Oct 03, 2009
Start problems
Is it under warranty ? I would check this out with Honda first . Have look at the engine your self and check the piston .
Feb 07, 2018 | Honda Garden
Honda GC190 can't pull starter cord
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily then the valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Aug 29, 2012 | Honda Garden
Broken pull cord
Pull cords can be purchased from your local hardware stores. If the handle just broke off, and the cord is fine, the handle itself can be replaced.
If you are uncomfortable performing the work, just look for 'small engine repair' places in your yellow pages.
Jul 10, 2012 | Honda Garden
Excell vr2522 pull cord jammed
Is the garden hose connected and turned on?If so make sure that the trigger on the gun is being pulled while your trying to start the engine! The backed up pressure in the high pressure hose can mimic a blown or seized engine in this situation.
Apr 15, 2012 | Garden
Honda water pump, wb20x/wb30x Left water in it over the summer, now the start pull cord wont budge, suspect corrosion,can I fix this myself, I really need this pump next spring, only been used this 1...
Remove the spark plug, this will rule out hydrostatic load on the engine. Try to pull it again. If it is still stuck, You will need to try to turn the pump.
Make sure there is engine oil too.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 03, 2010 | Honda Plumbing
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
Pull cord won't pull
I'ts a possibility that the engine has seized, remove the spark plug and look at it it will give you and indication if the engine is burned up.
Mar 24, 2009 | Honda Maxus Pressure Washer MX5222
Pull cord broke
if you have not replaced cord you will need to do this,when you fit the cord turn the pulley 4 or 5 times full circle the same way as if it was pulling cord,then feed cord through pulley and out of housing to fit handle when this is done you can let pulley recoil and you should have correct tension,hope this helps
Mar 10, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
