Question about Jenn-Air Refrigerators
My french doors 20 cubic frig is srarting to develop ice in the freezer. At first, I thought my wife was leaving the door cracked opened, but I have thawed it out twice and ice still comes back?
  • 4 more comments
  • ebstevens Oct 03, 2009
    Tks Ron...I've check for cracks around the door for seal problems & don't see any breaks. The frig, is 3 yrs. old.
    My setting display is 0 - 40
    Ron - I can hear the fan. The frost is accumating on the right side of the top rack and around the top where the light button is located. Also, when closed, I see a little water on the top of the freezer door between the frig doors?
    I have a setting dial in the frig. section for both freezer and frig.The freeze setting goes from +6 to -6
    And the frig dial goes from 45 to 33
    Yes ask another expert
    I'll try. The seal appears OK, however, I'll try the paper test. If that doesn't show me aproblem, I probably need someone on site. Tks.
    President:
  • 1,185 Answers
The door gasket is not sealing allowing warm air into the freezer
This trips the stat and the machine works harder to keep the temperature
Get a strip of strong paper and cut off a narrow strip about 2 inches wide and 12 inches long
Close this between the door frame and gasket then slowly pull on it
If the gasket is meeting correctly all the way around you should have an even pulling tension on the paper.
If the paper slips out easier in one place that the other then the gasket has failed and needs replacing.
Posted on Oct 03, 2009
  • 855 Answers
This problem can be common. Check the freezer setting and make sure it is ok. The other more common prolem is the door seal itself. Check the seal very carefully for cracks, tears, or deformaties. You may only have to replace the door seal.
  • 2 more comments
  • Ronald Park
    Ronald Park Oct 03, 2009
    Check and make sure the fan is working and the air bvents are clear and not blocked.
  • Ronald Park
    Does the fan run and the vents clear?
  • Ronald Park
    Also set the thermostat at 20.
  • Ronald Park
    Set freezer to 0 and fridge to 38. Check around button for light you may have a gap there causing the problem.
Samsung french door freezer will not open
Aha!
The Samsung wants the password.... in French! No!
Sorry.... couldn't resist....
If it's iced up then that would hold it shut until it melts.
Icing up is usually caused by a bad seal!
Sep 18, 2015 | Samsung RF217ACPN - 20 cu. ft. French Door...
GE Frig GSL22JFTA BS
If you get water at the bottom of the door then something is blocking it between there and the dispenser. Usually ice. Leave the door open and cover the freezer opening with a blanket to keep freezer cold.It should thaw in 156 or 20 minutes.
Oct 08, 2009 | Refrigerators
Frig has stopped making ice.
Open the left door open the ice maker door, up in the left hand corner you should see a green light, check to make sure that you have a selection chosen(either small of large cubes.
Jul 15, 2009 | LG LFX25960ST Stainless Steel French Door...
LG refrigerator NOISE
I have the sam eproblem...another site I went to said it is ice build up on the fan. Unplug the frig for an hour (don't open the doors or everything will spoil) and then plug in...it may defrost a bit and allow the fan to turn freely.
Sep 10, 2008 | Refrigerators
Control pad flashing temp and all lights continuously and ice door continually cycles open and closed
With the problems it is presenting, I would say it's very likely.
However it may take a bit of detective work to find which board is defective.
Check a part suppliers link Here for price comparison so you have some ideas.
Jun 26, 2008 | Kenmore TRIO 77314 Side by Side Bottom...
Frig won't cool, freezer works fine
Defrost unit completely. You're frosting up. Then, avoid leaving the door open, leaving liquids and food uncovered. Clean condenser coils. If it happens again, you need refrigerant.
Jun 09, 2008 | Refrigerators
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
FRIG AFD2535DES FRENCH DOOR BOTTOM FREEZER
Is your freezer fan blowing when the ref. is running, should feel air coming out the vent then,,,when running.
Aug 27, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
