I connected a emachine monitor to my old computer that the monitor went out on. The screen keeps going black after a minute and I have to power the monitor on anf off to come back on.
SOURCE: Emachine monitor lose color.
HI Bernard,
This sounds to me like the video lead is loose. Could you please try the video lead each end and tighten the locking screws if possible.
Regards
Nick
SOURCE: Emachine 19" Widescreen Flat-Panel TFT-LCD Monitor
Your power/inverter board is in need of an overhaul.
The capacitors are failing and possibly a transistor.
If the screen showed any redness or pink whebn it was working, Then
there is a slight chance that one or more of the 4 lightbulbs in the
screen was going bad and finally went.
If you take it apart and send me a picture, I may be able to tell by looking at it.
I repair these boards on ebay
bammbammfran
SOURCE: Emachine E19T5W Monitor
I have more or less the same problem. Mine only stays on for a second though, but it started out like yours. I took it apart and found that the CCFL bulbs at the top of the screen were so poorly put together that they arced out and in the end melted the end of the back panel bulbs off. The monitor only lasted a year and a half and now it's toast unless I can find new back panal bulbs.
If the screen feels excessivly hot around the corners or if you here a snapping noises (arcing) yours is going the same route as mine. If you want to get rid of yours I'll take it.
SOURCE: E19T6W EMachine 19" monitor
Emachine is going to repair it under warranty.
Tnx for the help.
Bill
