Question about Philips WACS700 Shelf System
Source+Stop doesnt fix it
When turned on says "booting up" and hangs. When pressed Source+Stop says "firmware is damaged. Restoring a new copy from the backup" and then it hangs.
  • 3 Answers
When the unit remains at the booting menu it is normally a sign that your Hard drive has failed. The hard drive in the wacs700 seems to run extremely hot, probably due to it's encaged location and poor airflow. It is possible to replace the drive yourself but it is fiddly.
You could send the unit back under warranty or get it repaired.
I charge £50 + cost of the HDD + postage to repair the fault.
No fix = no fee but you will need to pay for return postage. I only replace faulty Hard Drives and don't carry out other fault finding repairs. HDD Choices up to 300GB.
Robsony@btinternet.com
Posted on Aug 28, 2008
  • 476 Answers
This problem is usually caused by the ribbon cable connection between the front panel and the main unit. Sometimes the problem can be cured by disconnecting both ends of the cable.
The firmware should still be ok in this case.
There are multiple processors in the WACS700 unit, and the problem occurs when they can't talk to each other.
An authorised service agent should be able to sort the problem with a replacement cable.
Posted on Mar 12, 2008
  • David Simpson Jan 14, 2009
    Further to my previous post I have run one of these on the diagnostic system.
    This problem can be caused by 2 things:
    1 - Failed or corrupt hard drive
    Display shows "Booting" and the hard disk can be heard spinning up.
    A faulty hard drive usually makes a regular clicking or clanging noise. In this case a replacement will be the only option.
    A corrupt hard drive will spin up as normal. In this case it be recovered by copying from another hard drive, using proprietry hard drive copying software on a PC.
    2 - Blown inductor on the hard drive power connection.
    This is indicated by "Booting" on the display, and no hard disk noise or activity from the unit.
    This is caused by one of the small black surface mount components failing on the hard drive power plug.
    These can be removed and replaced by a single strand of wire (eg from mains flex) taking care not to touch the wire anywhere else on the board.
    The inductors can be tested by a meter. Normally they should show continuity or zero resistance.
    www.cheapestelectrical.co.uk have a small number of spare parts for the WACS700, however they are not listed on the site.
    Contact them via the website with any queries.
I had this problem, what i did was to take the front of the center console and thee was a cable not conected. The cable becomes loose after you remove the front and is a pain to get back on
Posted on Mar 04, 2008
I have 8520 BlackBerry. Suddenly while changing application while typing in sms section and going to contacts to search a number to copy & paste it got hanged. And know whenever I go and press Mail...
hello.
this problem occurs when the Phone's Firmware is corrupted, in order to fix this problem you should update your phone's firmware, it's easy just look through the link below:
8520 Software Update
Sep 16, 2010 | RIM BlackBerry Curve 8520 Smartphone
I have hp dv4-1465dx, how to reset bios without having OS
I'll spare you the rant on dealing with "cracks" but will say that damaged or corrupted firmware in BIOS's is a major problem that is not always correctable. It is possible you have bricked your system. Especially if the BIOS is not in a socket but hardwired to the mainboard and can't be easily replaced.
The problem is that if the BIOS is the issue you aren't going to get past POST to read anything from any disk [hard, USB, CD-Rom] so the system becomes totally unbootable from any source because the system is unaware of any of these sources as the BIOS firmware hasn't provided the system the data to access them. None of the I/O's will function so you won't be able to flash the BIOS ROM with an replacement for the damaged code.
Your best bet is if your BIOS is socket monted, in which case you can purchase a replacement and swap it out for the damaged one which will resolve your problem as the code on the new one will be intact.
You can do it even if its not socketed, but un-soldering and re-soldering a BOIS chip onto a mainboard without damaging the tracings is no easy trick even for an accomplished repair tech.
Sorry I couldn't do better for you. I hope it works out.
Feb 05, 2010 | IBM ThinkPad R40 2722 Notebook
Have ide drive have put a new 60gig but cant load new os it finds the cd drive but wont boot from disk have changed bios but still it say ntdlr missing it drivin me nutts.
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows.
  9. Loose or Faulty IDE/EIDE hard disk drive cable
  10. .
To Fix
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot
Jun 01, 2009 | Fujitsu Siemens LifeBook S-6000 Notebook
Psp is very slow and doesnt load games. It is hacked. It started after someone put in the game Metal Gear Solid Portable Ops.
What you need to do is press the select button so that the M33 VSH MENU pops up make sure your CPU Clock XMB is set to 333/166, that should fix and issues because I had the same problem.
Nov 03, 2008 | Nintendo Game Boy Advance Console
System Doesnt start automatically
Did u try restoring Ur BIOS to default settings............
that might help
if it doesnt pls do post back a reply
Oct 28, 2008 | Computers & Internet
Ntldr
First check your bios & make sure it see's your hard drive & it's setup correctly. If it is there could can be other reasons for the missing NTLDR.
Suggest you take you Windows CD and boot to it. If your CD does not boot. Re-start the PC & start pressing the F8 key every two seconds. This will bring up a boot menue. Choose your cdrom drive.
Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy these two files to you Hd. copy e:\i386\ntldr c:\
Replace the drive letter listed above for your cdrom's drive letter.
Once copy has been complete re-boot your Pc.
If you still get missing NTLDR. Do a complete reinstall of windows. Your personal data should stay intact.
Please post back if this has not fixed missing NTLDR, there are more fix's that can be applied. I only listed the most common.
Feb 12, 2008 | AOpen Motherboards: AX4SG-UN (AAX4SGUN)
Nokia 6300 doesnt turn on
you have to reflash the original firmware the phone came with on the phone.
Dec 23, 2007 | Nokia 6300 Cellular Phone
Booting up
Probably corrupt firmware. You can re-load the backup and restore the system.
Press and hold the SOURCE and STOP buttons whilst plugging into the mains supply.
Continue to hold until recovery option appears.
If this doesn't work, then the backup firmware is corrupt too.
Dec 13, 2007 | Philips WACS700 Shelf System
WACS700/05 Wireless Music Centre will not Boot up
tried to hold source and stop got message firmware damaged retriving copy from backup. power turn off, hold down source only power on comes up booting up please wait but in the lite up mode, 30 seconds later everything back on
Aug 20, 2007 | Philips WACS700 Shelf System
Philips WACS700 Shelf System Logo
796 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
