Question about Amana Dryers
My amana dryer is warm but not hot I took the element out it looks ok now what
I replaced the thermostate and cleaned the unit good and it
is now working fine.
Posted on Oct 06, 2009
My Whirlpool duet sport dryer got hot and shut off after running 20 minutes.
Sounds like you may have a bad heating element that has grounded. You should have this looked at to make sure if you aren ot handy to open the dryer up and inspect the heating element your self. make sure the element wire has not broken and fused itself to metal inside the dryer heater housing.
Feb 02, 2017 | Whirlpool Dryers
How can I diagnose, isolate and repair my Amana, NED7200TW dryer it runs but will not heat?
Since you say it happened gradually seems like it's not the heating element. If that's functioning properly you should see the orange glow inside the dryer when running. If your dryer does not have a glass door you can keep the dryer running by holding the button in. Look on the door, at some point you should see something that makes contact and pushes a switch on the frame. You can trick it by manually closing the switch. Be careful. I would suspect the trouble is a clogged lint exhaust. Over time this will fill with lint preventing the moist air to escape. This is how the dryer works. The hot wet air in the drum needs to vent outside to dry the clothes. When this becomes clogged you have nowhere for the moisture to go. So it stays in the drum and runs and runs without drying clothes. Also make sure you clean out the lint trap after each use. Clean the entire vent path. Also make sure you are venting outside. If not, you are just recirculating wet moist air back into the dryer. When working properly, you should feel a good flow of warm wet air at the outside vent. If not there is still a clog. Good luck.
Sep 05, 2014 | Amana Dryers
MY ELECTRIC AMANA DRYER HAS 3 SETTINGS .ON THE LOW HEAT IT WILL TURN ON BUT DOSENT GET HOT . ONT THE OTHER TWO SETTINGS IT JUST BEEPS AND WONT START.REPLACED THE HEATING ELEMENT AND THERMAL FUSE BUT STILL...
I would keep my patience and use the warm settings and use the cloths airer to finish the dry ing.
sorry for my late answer but I have not been feeling wellfor the past months-OK now or almost.
good luck
Kolbrun
Nov 22, 2011 | Amana NED7200TW Electric Dryer
Dryer does not get completely hot. Kenmore 110
most likely this is due to a build up of fluff in your filter, when this happens air can not escape and youl find your washing to be warm but still wet and far from dry.
Sugest you clean your filter, any problems feel free to get back to me
Feb 12, 2010 | Kenmore Dryers
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
Dec 11, 2009 | Amana ALE643RB Electric Dryer
Amana dyer model ale956eaw, won't heat up, all
if all other operations of your dryer are ok possibly your heater element or thermostat are faulty also there may be damaged wiring you will need to look closer and own a multi meter to check properly keep me informed of how you went
Nov 07, 2009 | Amana ALE956EA Dryer
Maytag ele dryer only gets warm
You have two breakers that control the heating elements.  Check both by turning off then on.  If one is open, the motor will still turn.
Nov 23, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Amana dry wont dry
partially bad heat element. some models have a double element maybe half of it is burned out
Nov 17, 2008 | Amana NDE2335AY Electric Dryer
Overheating dryer
blowing when the tube is off usually = dryer fan ok, and is a sign that the duct is blocked past that point,
most commonly there is a blockage in the vent hood, the screen that keeps bugs and rodents from gralling up the exhaust, is also very good for catching any lint that squeezes past the lint filter.
most exterior hoods can rmove the screen for cleaning
any flexible ducting is a likely ara as well, the corrugations make a lint trap
check also that the duct from the heater element into the drum is not dislocated or blocked
Oct 23, 2008 | Amana Dryers
Dryers Logo
37 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
