Use softwares like magic installer etc. from softpedia
There is an application called Revo Uninstaller
(Freeware). Install it on your PC and then uninstall recovery commander.
Hope this helps.
Hope this helps.
Hope this helps.
For you to Stop it you need to stop the services
running for it. Follow the steps below.
Click on Start and then Click on run. Type
msconfig. In the System Configuration utility screen click on services tab (Its
on the Top). Once you are on that screen check the option Hide all Microsoft
services. Then look for Recovery Commander. Uncheck that. Uncheck the Hide all
Microsoft applications again. Click on apply. Then click on OK. Reboot the
computer. You will System Configuration utility screen. Check the Option Don't
show this message again and then click on OK.
Note: DO NOT uncheck any Microsoft Services.
If you want to delete it or remove it from the
computer then install Revo Uninstaller (Freeware).
Hope this helps.
Have you gone to software uninstall on Control Panel?
