Question about Vacuums
My hoover will not suck
My hoover will not pull water back out of the carpet!
  • 328 Answers
Re: my hoover will not suck
Well since you dont mention a model or brand, it could be a few things. If it has a pump check that it isn't blocked. It could be a loose coil or a blocked hose. You need a bit more info here.
Posted on Dec 29, 2007
0 characters
3 Points
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Instruction manual for hoover swish carpet cleaner
my hoover swish dosent seem to **** up much of the water out of the carpet carpet is still quite wet and bot much water is sucked up for the amount of water that goes in the water dispenser
Nov 26, 2010 | Vacuums
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Al Terrain Spin Scrub motor running in reverse
if it dosent **** up the water send it back but some hoover steamvacs blow air to dry the carpet or floor faster
Aug 01, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover Steamvac Ultra
make sure all parts are snapped in again i did the same thing.......
Mar 17, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SpinScrub Carpet Cleaner
I was having the same problem, the black seal under the tank that captures the water was broken, and it wasn't getting any suction.
Nov 05, 2007 | Hoover V1 SteamVac SpinScrub Vacuum
Vacuums Logo
152 people viewed this question
Top Vacuums Experts
Roger Potts
Are you a Vacuum Expert? Answer questions, earn points and help others
