Question about Hunter 52" Ceiling Fan With Light And Remote Control
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in box, another black unlabeled, red with stripe-?, blue labeled to lights, green-ground. Need to know which wires hook to which if only a remote control is used that has a one button for lights (push one button for intensity) and one button for fan(push one button to change speed)
  • Anna Cuomo-Bertsch
    Anna Cuomo-Bertsch Oct 04, 2009
    I was looking to wire a remote to the box. The fan was already wired to the remote. The issue is moot because the carpenter who took it down to do other work never marked the wires, promptly forgot how it went together and shorted out the remote trying to prove he knew what he was doing. Will now have to wire it direct and use the pull chains.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
Posted on Oct 03, 2009
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
Need to know how to wire this fan. Not using a remote or wall switch
Hello! W/D here.
In your ceiling box, you'll find 3 wires; black, white and bare copper.
In your fan, you'll see 4 wires; black (or red), white blue, and green.
With your breaker tripped, connect the green wire on the fan to the bare wire in the ceiling (this is your ground).
Connect the white fan wire to the white ceiling wire (this is your common).
Connect the blue and black (or red) together, and connect these to the black wire in the ceiling (this is the hot lead, and will supply power to the fan and the light).
Best regards, --W/D--
Feb 13, 2011 | Westinghouse 78500 Casanova White Ceiling...
I just bought a switch to control both fan speed and light control (dual switch) i hooked it up every thing worked fine. then to realize that the outlets that follow dont work. just as a clue on the...
The key seems to be that you changed wiring in the ceiling box.
I suggest you make a drawing of the wires before and after. Track the route that the Hot wire takes.
The key question is this: Does Hot wire from breaker box arrive in the ceiling box first? Or does it arrive in wall box first?
I think Hot from breaker arrives in wall box first. And from there Hot wire goes to ceiling box ... and from ceiling box the hot wire goes to other plugs in room. If this is true, you will be one wire short for installing fan control switch.
I always make a drawing of existing wires before starting, so I can put it back the way it was. It sounds like you got a good handle on which wire goes where.
We used to solve the one-wire-short problem by making a simple project bigger. Figure out which direction ceiling joist run. See if you can slide fish line from fan ceiling box over to wall. If that works. Over at the wall, chop small hole in ceiling so you can feed wire up to fish line. Pull wire over to ceiling box. Next, staple other end of wire along ceiling over to location above wall box. Chop another small hole so you can feed wire down to wall box. And then install beautiful crown molding to hide the mess, and paint the room so you need new furniture.
Oct 02, 2010 | Electrical Supplies
Hello, I have to install a Hunter universal remote receiver, Model 27185 toa Hampton Bay ceiling fan w. light, Model 468-282 today. The receiver has 5 wires, red to light, black to fan, a live black to...
Red from receiver to blue light feed. Black from receiver to black feed to fan. White common from receiver to ground.(bare copper)
Black from receiver (hot) live in, to black from household wiring switch. Common in from receiver to neutral (white ) from house (switch.)
Sep 26, 2010 | Hunter Ceiling Fan Remote Receiver...
Bought a hunter remote and can't figure out what wires to connect
The remote red wire should go to the black wire that goes to the light. The remote black wire should go to the black or black with white stripe wire to the fan. The white wire should go to both white wires from the light and fan.
The power in (black and white) should be connected to your power source black and white. Bare copper wire to ground on fixture
Jun 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Wiring a ceiling fan w/light
To add to red54's comments:
This is what I believe you have:
- one source in the ceiling box (black & white)
- one donwline circuit in ceiling box going to another wall/ceiling box (black&white)
- on switch wire in ceiling box coming from your wall switch (black & white) -- this is the white wire which will be hot when the switch is truned on
Here's how it should be connected:
- all 3 blacks in ceiling box connected together -- no other wires in this bundle
- white wire (which is hot when switched) coming from switch connects to the black/blackwhite fan wires
- connect all reamining white wires together in bundle
- connect all ground wires together
It's that simple. Trick is figuring out, of the three cables in the ceiling box, which is source, which is downline, which is switch.
Maybe red54's procedure can help you figure that out.
May 09, 2009 | Hunter 22890 52'' Low Profile Plus Antique...
Ceiling fan
OK, the wires coming from the top of the fan are going to go into the junction box in your ceiling. Out of the ceiling, you should have a white wire, a black wire, and a green or bare copper ground wire. Make sure your power is off at the fan. Your wires coming out of the fan should be white, black, blue, and a green ground wire. Pull the wires through the top of your fan, and connect the white to the white in the ceiling, the black and blue wires from the fan to the black wire in the ceiling, and then connect your ground wires together. Make sure you use wire nuts and twist them firmly onto the ends of the wires. If you happen to have a red wire coming out of the ceiling as well, just put a wire nut on it and stuff it back into the ceiling box. The blue wire is what works your light kit, and the black is for the fan. Hope this helps you!
Jan 05, 2008 | Casablanca Fan 3245T Ceiling
Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Dec 29, 2007 | Hampton Bay 52 In. Black Huntington III...
Installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Nov 17, 2007 | Dryers
Dryers Logo
219 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
