Question about Refrigerators
How do I clean the coils on the bottom of my refrigerator. I bought a brush made to clean the bottom but when I got home the coils run 90 degrees opposite of the direction you can use a brush.
  • hopeful24 Oct 05, 2009
    There is no room to get around the coils. They form a w shape when you look from the side with no room to get around them.
    Filmmaker:
    Uploaded 5 video answers.
  • 11 Answers
I\'ve been struggling trying to keep our 2 goldens dog hair from the coils of our 8 year old Kenmore side by side with "W" compressor coils, but like everyone else was unable to clean past the first set of coils.
I came up with this solution that worked to get much of the big stuff, hair and bunnies, off of the further back coils. Not perfect but much better than nothing.
Removing the back lower panel I was able to snake a crevice attachment from our vacuum down the right side of the coils (left side looking from back)
Looking from front"
I made a compressed air contraption to blow the dust/hair across the coils using a compressed air nozzle that I added a 10" long tube and a 90 degree deflector
From the front of the fridge, on the left side of the coils, I snaked the compressed air nozzle towards the back and started directing the air stream blowing towards the vacuum crevice tool at the opposite side of the coils.
The compressed air dislodged the hair/dust enough that the vacuum was able to suck it away. Again, not perfectly but certainly much better than I was able to clean the coils in the past.
I suppose you could use a can of compressed air and add some sort of deflector if you don\'t have a compressor.
I then got to thinking how to prevent the dust from accumulating on the coils, I\'m going to try an air conditioner filter. I cut it slightly oversized to fit the front opening then split it in half to make it thinner for more air flow.
Picture taken before making the filter thinner.
For years I had my calendar remind me monthly to vacuum the coils but now hopefully I\'ll be able to simply change the air filter.
Posted on Feb 01, 2014
    President:
  • 1,304 Answers
I use a shop vac and a dust brsuh
Posted on Oct 03, 2009
How do I clean the coils on my Maytag freezer-on-bottom fridge? (Model #i is MF D 2560HEW)
HI,
Pick up a coil brush from you home improvement center near you and remove the grill in the front under the freezer door. With the brush, brush the coils under the unit to clean them. Have a vacuum handy, you will need it for dust and hair if you have pets in the home. Good Luck
Apr 20, 2016 | Maytag Refrigerators
Do i need to clean coils?
you dont new unit are sealed, some have a filter in front at the bottom vent.
Sep 23, 2012 | Maytag MSD2651 HE Side by Side...
My subzeero fridge is running contineously
Clean the coil, its the best thing a home owner can do, they sell a brush just for that and then use a vacuum to control the dust. If the coil is already clean, (good job). I have seen units have problems when there was just dust on the coil nothing major blocking the air flow.
Jul 02, 2011 | Sub-Zero 650 / O Bottom Freezer...
How do I go about 'cleaning the coils' on a GE profile model - freezer is having trouble holding 0 F and I was told this would help. thanks
It is not necessary to clean the evaporator coil.
The condenser coil underneath may need cleaning.
Use a long handle bottle brush and a vacuum cleaner.
Your refrigerator freezer temp will fluctuate from minus 5 degrees to plus 18 degrees on a regular basis.
It will not be a steady temp.
Jul 24, 2010 | GE PDS22SBRLSS Bottom Freezer Refrigerator
My home air conditioning unit only blows cold air
You have an air flow problems. Clean the outside condenser coil I use on half baking soda and one half joy soadp squirt this on the coil take a coil brush that you can buy at any hardware store. and go up and down on the coil. then take the water hose and squirt it down to clean the soap and dirt off, It this doesn't solve it you will need to clean the fan blower motor the squrrel cage but don't get the motor wet. Next you will need to clean the evaporator coil just take the coil brush and go up and down to clean. This should solve your problem, What kind of readings did you get on the low side and high side. You should have a 40 degree drop across the evapartor. And the high side should be the out side temp and 30 degrees. If you have any questions you can email me at crislsparks@gmail .com. What kind of freon does it the unit take. It will tell you on the nameplate on the outside unit.
Jun 25, 2010 | Ruud UAKA042 Air Conditioner
Our Kenmore EVL165NXRQ03 fridge/freezer (single unit with either freezer or fridge) never gets below 54 degrees and hasn't since installed gotten below 50 degrees. Could it be in demo mode ande if so how...
How old is your refrigerator? Old enough for lint and dust to have accumulated around the bottom fan and coils?
Dirty coils can cause a multitude of problems and even give the appearance of a failing unit. Try cleaning the coils with a brush and vacuum as thoroughly as you can and be sure the bottom fan is running to pull air over them. It's a 'free' fix and you'd be surprised at how often such a simple 'repair' is all there was wrong with a refrigerant unit.
Good luck. Hope this helps.
Sep 12, 2009 | Refrigerators
I have a Samsund SRS579NP both fridge and freezer not getting to right temperature. I don't think that the temp gauge is working properly. the fridge says that it is -1 degree but its deffiantly not that...
My first thought is dirty condenser coils (the coils on the bottom of the refrigerator behind the kick panel). You wouldn't believe how much impact a large accumulation of dust and lint on these coils can have on the efficiency and operation of a refrigerator. It's also one of the least expensive 'fixes'... It's FREE.
Remove the front kick panel and, with a flashlight, look at the horizontal coils under the refrigerator. If they are covered with a thick layer of dust and lint, you can almost be assured that this is the problem. They make tapered brushes specifically made for cleaning these coils, but any long slim brush that you can get between them to clean off the accumulation of dirt is better than nothing.
You can do a more thorough job if you pull the refrigerator out and remove the back panel to clean from both front and back. Be sure to unplug the refrigerator while you do this to avoid the condenser fan from coming on while you're working. It's always advisable to use a vacuum attachment to actually REMOVE the dust and lint from the bottom of the refrigerator rather than leaving it under there to be drawn back up into the coils very quickly after you've cleaned them off.
There's no specific definition of 'clean' coils, but my advise is to clean them as thoroughly as you can and be sure to clean off the small condenser fan as well.
Put the panels back in place and plug the refrigerator back in. This should do the trick. Dirty condensers can make you think your whole refrigerator just when ka-pooey when this easy (although somewhat dirty) task can make it run like new again.
Hope this helps.
Jun 28, 2009 | Samsung Refrigerators
I have a 10year old Amana 25cu SRV26V side by side and our freezer and food area is not very cold. The freezer side is only 20 degrees. Both sides have been turned up to 7 as high as it can go since...
Hi: It's a sealed system so if you need a recharge it will be expensive. You mentioned that the "air filter" in the back was clean. Do you mean the panel at the bottom of the back of the refrigerator? The coils are on the bottom (parallel to the floor across the bottom) and have to be clean. If you haven't done this; remove the grill and vacuum the coils. It's best to use a coil brush to get to the very back. A refrigerator coil brush is available at Lowes or Home Depot. I use an air compressor to blow them out. Then I have to dust the house. If the coils haven't been cleaned this will cause what you described. I hope this helps, Jeff
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Not cooling enough per the display
I have this same model which I think I bought in 1988. My frig was overheating also and the compressor was extremely hot. I too cleaned the condensor coils again and have been cleaning them at least annually for a decade and a half by putting an adapter on my small vacuum cleaner. This time I took my 6 hp shop vac and a long bottle brush and scrubbed the coils clean running the brush over the coils many times and using a trouble light to help identify where all the accummulated dust was. Frig is working perfect again. Exhaust temperature is substantially reduced. Hope this helps.
Apr 30, 2009 | Kenmore Refrigerators
Sub Zero isn't cold enough
Sounds like it might just be a simple as a dirty coil. Use a coil brush (you can get at homedepot)
cdda64b.jpg Clean the dust and from the back and bottom of the fridge. The coils pickup alot of dust over time making the fridge become ineffecent. One some subzero units your condenser coils are on top. Use the brush in conjuction with the vacuum to get it clean and watch your fridge for a hours to see if that helps before you call a repair tech out. Make sure you unplug the fridge when your doing this.
Jan 29, 2009 | Sub-Zero Bottom Freezer Refrigerator
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
