Question about HP J3680 Officejet All In One Printer
How do you scan something - HP J3680 Officejet All In One Printer
How do you scan a document onto your computer
If your printer supports scanning, then the main issue you have is
software to control the printer and DO something with the document once it is scanned. Readiris is what I use. I have version 11 and I think they are up to 13, but it works GREAT. There probably are other pieces of software out there to handle scanning and result document manipulation. With Readiris, you can make the scanned item directly into a jpeg or a pdf. which is really useful. You might want to try download.com and search there. Good Luck
Mar 09, 2013 | Canon PIXMA MX340 Wireless Office...
Lexmark x4270 black streaks on scanned images.
There is something on your scanner glass; oftentimes, this happens when you use white-out on a document and then scan it. You will have to open the cover to access the scan plate-it should look something like a simple piece of glass maybe an inch wide. Use rubbing alcohol or glass cleaner to clean the glass plate-DO NOT spray on the plate, spray LIGHTLY on the cloth or tissue-use something soft that will not scratch the glass-and use that to clean the glass plate. You may have to do this several times to remove the foreign matter from the plate, testing between cleanings until you get a scan that is clean.
Feb 11, 2010 | Lexmark X4270 All-In-One InkJet Printer
How doI scan something?
To scan something from your printer to the computer you should have the hp solution center installed in your computer double click and open the solution center place the document or the picture that you wnat to scan on the glass bed of the printer (the text content should face towards the glass)
now click on the scan document or scan picture button on the hp solution center a window will come up click n the scan button then a window will come up showing the preview of the scaned document or picture click finish to finsh the scan
now you can view your scan by going to the MY SCAN folder in MY DOCUMENTS
Jul 30, 2009 | HP OfficeJet J4580 All-In-One Laser...
My Xerox Documate 510 adds a line from top to bottom down each scanned document. The line only appears when something is fed into the paper feeder and does not happen when scanned single sheet at a time on...
you probably have something on the scanning bulb when it goes through the feeder. The scanning bulb is directly to the left of where you use the flatbed. Clean that glass with a dry, clean cloth and you should be back in business.
Jan 11, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Want to delete
When you scan things, it gets saved to a location on your computer as a JPG (image file). In the program you use to do the scanning it should tell you what folder it is in, it'll be something like "C:\Documents And Settings\Abc\Something\...". Or maybe "C:\Program Files\Canon\Abc\Something\blah...". Each scan is a separate image file. All you have to do is go to Start->My Computer, then navigate to the location where the files are being saved using explorer. Then select the offending image and hot delete.
Don't deleting things that aren't your scan, though. You can break your computer that way.
Dec 12, 2008 | Canon Office Equipment & Supplies
NO scan beam
do u get a red dot?
if u do there might me something stuck in the scanner.
Mar 17, 2008 | Symbol PDT 8146 Portable Terminal
Brother dcp 7020 Scanning to e-mail
with Brother -photo capture-copy-fax-scan machine, I can do except scanning. Please show me how to enable scanning
Feb 01, 2008 | Brother DCP 7010 Multifunction Laser...
Hp 1350 printer will not scan.
You need sofrware that captures the scan from the scanner. usually comes with the printer, you have to opemn the program and tell it to scan and save.
Scanning by just placing a paper on the scanner and pressing the scan button just tells the printer to scan and probably print a copy, but it doesnt send it to the computer unless theres a program asking for it. Check the installation cd and go through the software that came with it.
Jan 30, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP J3680 Officejet All In One Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
