Question about HP w1907 LCD Monitor
My monitor goes to sleep all the time it is very frustrating
  • HP Master
  • 5,568 Answers
Check the settings for 'Power Options' in your control panel; it may be set up to 'sleep' after some short period.
- Open the 'Start' menu - Select 'Control Panel' - Open the 'Power Options' folder to check or change settings.
CRT monitors could develop 'burn-in' and having them go inactive after a period on non-use made sense to avoid damaging the phosphor but LCD monitors don't suffer from that so the feature isn't as useful as it once was.
Posted on Oct 03, 2009
    President:
  • 2,049 Answers
Go into Control Panel, then to Power Options.
In XP, you see a selection for Turn Off Monitor. Adjust that setting as desired.
In Vista, you'll see Choose when to turn off display on the left side. Choose that option and select the desired time setting to turn the display off.
3 Suggested Answers
  • 8 Answers
SOURCE: after monitor goes to sleep comes after several push on button
Look for bulging capacitors on the board and replace with the same type. Have a repairman help you.
Posted on Mar 06, 2010
  • 732 Answers
SOURCE: My monitor goes to sleep all the time, not
trevor_jody, I hope you have valid HP warranty! If not , then you will need to do some reading at this blog: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ The cheapest way to fix is DIY. But you and only you can determine if you are able to do the required work necessary to refurbish the unit. Swap-in a good unit to use while you are researching the common fixes for your 2338h unit. Your unit still works!!! Just not long enough! Your goal is to make it work for 20 million seconds. Try these other web sites also. www.ccl-la.com/badcaps.htm (site run by "buddymc") and www.badcaps.net , www.lcdparts.net Next thing to do will be to understand the "flashlight test" to determine state of your monitor's "switch-mode-power-supply". Is it in full or partial shutdown mode when screen goes BLACK or BLANK and BLACK? If you can still see Win-desktop after screen goes black, then SMPS is in partial shutdown mode. Blank n black=full shutdown. Do some reading in my and "buddymc" and "budmrtn" fixya profiles by typing our fixya "nicknames" into the "search for solutions or.... " bar at top of fixya screen and then hit enter or click search button. You will also find DIY video clips at YOUTUBE that will also be of some use too!! All that we ask you to do after doing your research is to come back to fixya and tell us if we were of some help and that you have learned something about how your monitor functions and if you have been able to make the decision to DIY or contract out the work needed to restore your unit to like-new condition. Bye for now. 12fixlouie
Posted on May 04, 2010
Testimonial: "Helped me troubleshoot, have not fixed yet, flashlight test shows display is working, backlight is not."
Samsung monitor goes blank after working perfectly for a period of time.
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Dec 06, 2015 | Samsung 933BW 19 inch Monitor
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
Hi ,My dell screen goes to sleep mode after a long wait of not being used, say an hour, ..............but the pc sleep is not set ? The message comes up to move mouse ,or press any key ,but this does not...
please check your monitor settings may be sleep time is defined there. secondly check your system sleep time again. and also check window power saving mode. may be your system goes to power saving mode.
If you like this rate me kindly
Oct 12, 2010 | Dell E153FP 15" LCD Monitor
I have a HP vs17 monitor that keeps going to sleep. It will flash to windows when I first start and immediately goes into sleep mode. When this first happened, I had managed to make sure any sleep modes,...
trixieb1, It's NOT going to sleep mode. Use warranty if possible!! If that not option you will need to read about "cold-cathode-fluorescent-lamps" and the voltage inverters that power them. Learn to do flashlight test when screen goes to black or blank n black!!! Read my fixya profile and those of other ccfl back-lit lcd monitor technicians. We already know what is wrong with your unit. And It is a VERY big problem for all LCD monitor manufacturers. Just do some reading before you do anything else. Good luck with the repair. 12fixlouie
Mar 31, 2010 | HP w2207 Monitor
My HPw1707 monitor keeps going to sleep and I have to turn off the computer to get the programs to open when I want to work on anything.
Are you saying that the monitor is going to sleep or the computer? If the computer goes to sleep I can understand not being able to get to your programs. This is a simple matter of turning off hybirnate in the power supply icon of your control panel. If the monitor is going to sleep there should be a menu with a timer for sleep time. Just change it to a much longer time or turn it off.
Feb 25, 2010 | HP Computers & Internet
Monitor goes to sleep after not being in use and then won't wake
Check the "power options" settingsin your control panel.
Nov 16, 2009 | HP W2007 LCD Monitor
How to get HP1907 back from sleep ?
You need to check the display connector, perhaps a pin is broken. Set the power saving features at the Display properties.
Oct 30, 2009 | HP w1907 LCD Monitor
Monitor says it is going to sleep and there is only a black screen.
Monitors go to sleep when there is no computer activity it detected. Also, when your OS is working and somehow you have set a "sleep" time, then the monitor goes to sleep at the appointed time. Just press ENTER or press the POWER BUTTON to bring it back to life without losing your computer work.
Oct 29, 2009 | HP f2105 21" LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor issues
well i think ur screen saver setting r responsible for that if u increase the time ur problem will be solved. or ur power setting r responsibe for that u need to change the time setting there to . u can do that by clicking on start then going to control panel then power settings.
Jun 24, 2008 | Gateway FPD1975W 19" LCD Monitor
HP w1907 LCD Monitor Logo
237 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
