Question about Dell Dimension 4600 PC Desktop
No sound The speakers do not work. I think the outlet (?) in the computer is short-circuited or something.I plugged my speakers into the back of the computer. No sound comes out.Help please. Thanks.
  • 4 more comments
  • fasola Dec 21, 2007
    Thanks!
    the power is fine
    the plugs are fine
    I used a pair of functional speakers
    when I used headphones, there was no sound.
    Another thing is : the computer states that there is no sound device in the computer..which clearly was not the case.
  • fasola Dec 31, 2007
    "Open control Panel, open Sound & Audio Devices. Click on the Audio tab. In the sound playback section a device should be shown. "---For some reason, there is no device under the Audio Tab.
  • Anonymous Jan 08, 2008
    the power is fine
    the plugs are fine
  • Anonymous Mar 29, 2008
    Philips computer speakers:
    1. No sound
    2. When plugged in, no sound
    3. Installing speaker problems
  • Anonymous Mar 31, 2008
    yes thank you for the help
    President:
  • 2,351 Answers
Try plugging a known good headset into the jacks behind the PC. Still no sound! Open control Panel, open Sound & Audio Devices. Click on the Audio tab. In the sound playback section a device should be shown. Click the Voice Tab, the same device should be there as well. Lastly, Open (System) while in control panel. Click the (Hardware) tab & than click Device manager. Scroll down to Sound, video & game controller. Do you see a yellow !. If yes there is a problem with your intergrated sound controller. You can try downloading & installing the sound drivers
for your PC at : http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If that still does not help than install a PCI sound card to your PC. Install the CD that comes with it.
Posted on Dec 21, 2007
  • 59 Answers
Check all your volume settings in windows, and check all your sound settings in windows first.
If you are sure its a hardware problem
try different speakers or headphones to make sure its not the speakers. Make sure its the output/speaker jack that you are plugging into. In many cases the jack wears out if you keep on plugging speakers in and out of the jack. In that case you can stick a small piece of aluminum foil inside the jack to add some conductivity. If that doesn't work, the sound card has been short circuited i suggest disabling it in the bios if its onboard sound card, then buy a new one and install it.
  • stejeda777
    stejeda777 Dec 22, 2007
    Check your BIOS and make sure the onboad soundcard is Enabled before installing the drivers.
    Rule out the possiblity of the sound driver being the culprit as the other gurus have suggested by following their instructions. Reinstall the sound driver that came with your computer, or download a new one from the sites linked here.
    You can tell the sound jack is shorted out, or has worn out if its really crackly and noisy when you have the speakers jacked in while playing audio. Only thing you can do in that case is resolder it or buy a PCI sound card.
  • 36 Answers
Is this a Dell Dimension 4600 PC Desktop?
If so I can help you find sound drivers for it. You have to figure out if the speakers are the problem if you do not get an obvious error to indicate that it is a software problem.
Have you;
Checked power?
Checked plugs to make sure they are in the right place?
Swapped out the speakers with a set that you know work?
Used headphones to make sure the sound is actually coming out of the computer?
Let me know the answers to these questions please.
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My logitech z-640 speakers have quit out on me. i think there's a short in the cord where the 3 jacks are. they are awsome speakers and i just wanna fix them. what should i do?
well you &hash39;s why do you think there is a short in the cord did you hear static?
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 14, 2011 | Logitech Z-640 Computer Speakers
Computer won't turn on after short in electrical circuit
Hi:
You might just need the power supply on your computer tower replaced. It is about $40, and not that hard to swap out. Most computer stores will test it for you for free too. If they test it and its good, then you might have further damage to your tower from the power problem, but the power supply would be the most likely problem
Feb 05, 2010 | Computers & Internet
I unpluged back left speaker, forgot to turn off the power and the wire somehow droped down on the floor and smell burn with sound of shot circuit between + and - , after that my speaker does not make any...
Sorry, once there is short circuit happened in one of the component of a set devices mainly your surround sounds speakers and since they are all interconnected of there will be a chain reaction, one short circuit runs through the other device and then another short circuit will happen.
To make it short, if your speakers still have a warranty contact the manufacturer for support and most probably parts replacements.
If all else fails, purchase a new one...
Please never forget that on all electrical and electronic devices, especially home appliances, NEVER PULL OUT THE PLUG IF ITS TURNED ON, TURN IT OFF FIRST.
Hope these helps.
Nov 04, 2009 | Logitech Z-680 Computer Speakers
No sound
try rolling back the driver,or go online to update it...."sound driver"maybe it is the jack plug outlet.....as a quick check,turn the system sound nearly right down,and quickly plug in your headphones into the jack outlet,if you hear anything through the head phones"not wearing them"then its the lead and jack on your speakers..
Aug 02, 2009 | Logitech X-230 Computer Speakers
Sound problems
your speaker connections are plugged in incorrectly or the speakers are not plugged in and powered on.
check the back of the computer where your speakers are plugged in and make sure you speakers are plugged into the right colors
May 31, 2009 | Computers & Internet
Where do I plug the speaker in?
Please be more specific - Usually on the back of any computer you have 3 outlets at your sound card:
one is for "mic" (pink)
one is for "speaker" (green)
one is for "line in" (blue)
Oct 07, 2008 | Dell AS500 Sound Bar Computer Speakers
Help me
Friend one solution for this problem is to reinstall your soundcard driver if you use one or your windows media player software to see if you have deleted something in your PC. But check the connection of your speaker if it is plug correctectly from your power outlet, if it is plug correctly to your PC input/output pls. check the whole connection.
If after doing these things your speaker works pls. don't forget to rate me. Thanks!
Jun 23, 2008 | Audio Players & Recorders
No sound
I FOUND THE SOLUTION (at least for the led text blinking in and out with no sound).
It's the Altec's Circuit board!!!. If you take it all apart (not too hard) and within the circuit board where you plug in all your connectors (i.e. speakers, computer jack, etc.) , take it all out. Once you open the casing, you will find a couple connectors with wires (yellow, blue, green) plugged onto the board. Unplug both connectors on the board. (Careful!, one of the connectors, smaller one, are glued onto the board, but what I did was cut it off using a blade (box cutter)). After you take it apart, there will be two pieces of circuit board facing each other, one top (small), one bottom (big) (where all your speakers plug in to). On the top board (smaller one) wipe up the "rust" looking stuff on the back of the PCB board with little damp cloth. After you get most of it off, it will work again.
(How you know if it's the top of bottom is how the capacitors are working.
WOO HOO!!! I love these speakers!!!
Also, if your bass is weak, I found on another forum that it's the capacitors. Get those replaced at a local electronic repair shop. Find them on Google maps.
Please let me know if this works for everyone. THANKS!
Nov 10, 2007 | Altec Lansing ADA 885 Computer Speakers
Speakers set up properly, but no sound from PC
I have set up Koss desktop speakers properly (I think) -- they are plugged into the power outlet, plugged into each other, and plugged into the CPU of my computer. But there is no sound at all coming out -- just silence.Can You Please Help Me
Oct 16, 2007 | Koss HD 50 Computer Speakers
Dell Dimension 4600 PC Desktop Logo
151 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
