Question about Roper RAS8445KQ Top Load Washer
Bottom not spinning - Roper RAS8445KQ Top Load Washer
    Problem Solver:
  • 5 Answers
You may get lucky and just a belt has broken. An independent repairman could fix this for under $100. It also may be the transmission, which would be much more expensive. If the machine is older and the repair is between one third and one half the cost of a new washing machine, just buy a new one.
Posted on Oct 31, 2009
My Hotpoint WML560 won't run a full cycle.
Is there a no spin button that has been pressed. Also some delicate cycles have no spin as part of the program.
Dec 14, 2014 | Hotpoint Washing Machines
Hoover UH70935 windtunnel agitator spins like crazy with plate off after cleaning but will not with plate replaced.... what is going on?
If the brush roller was removed, it may have been reinstalled incorrectly, causing it to bind on the bottom plate.
Aug 08, 2014 | Hoover WindTunnel 3 Pro Pet Bagless...
Telmann TEL6TL washing machine doesnt spinn properly, brake motor not activated
replace whole mechanism if cheeper than replacing unit and dont want to pay a pro
Jun 19, 2012 | Washing Machines
Leaking from bottom on spin. also makes rattling
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 10, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Water will not drain, drumb won't spin
check water pump for faults and or blockage it will not spin as there is to much water inside once it has drained it should spin this is a safety feature
Jan 15, 2010 | Kenmore HE2 Plus Front Load Washer
Spinning to slow closes still wet
Hi, how are you?
I'm guessing you have a clogged pump and is preventing the machine to go into the final spin cycle. It's very common with these frontloaders.
You just need to take the bottom plate off (3 screws on the bottom) and open the coin trap and clean it out. It should be right in the front. Try that and let me know what happens.
Thanks!
Ned
Jun 01, 2009 | Kenmore HE2 Plus Front Load Washer
Will not spin in final spin
there is likely a blockage in the pump/bottom water feed hose. check out the filter and if clear you will have to clean out the bottom hose.
Apr 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Model # 23662200,will not spin
Look under the machine and locate the bottom of the gearcase. Inspect the bottom of the gearcase for oil. If oil is present, the gearcase will have to be replaced and the oil has probably migrated to the spin clutch causing it to slip during spin. Check your owners manual for limited warranty. The gearcase may have a 5yr warranty.
If you need further assistance, let me know
Regards,
reg501
The FixYa Team
Jun 26, 2008 | Kenmore 22422 Top Load Washer
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Roper RAS8445KQ Top Load Washer Logo
98 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
