Question about Cameras
I have a DMC G1 with 1.1 firmware. I note that there is a 1,4 upgrade. Do I need to uprade to 1,2 first and so on, or just upgrade the latest version
3.5 firmware upgrade
Ae you sure of the version number ?
You printer is listed as Current model and is not obsolete. However
the latest firmware (Nov 30, 2009) seems 3.15
Note the 3 different files based on your serial number
http://www.sony.net/Products/DP-driver/digitalphoto_printer/UP-CR10L
Apr 15, 2016 | Sony SnapLab UP-CR10L Digital Photo...
I have the samsung captivate sgh-1897 . I've tried to perform a system update but it says no firmware. What do I need to do to get firmware on my phone
An upgrade and an update are two different things. If your device has the latest version of software/ applications, it will show that there are no latest updates available. A firmware upgrade is posted by Samsung or you do a custom upgrade. check custom upgrades for further clarification.
Nov 09, 2015 | Samsung Cell Phones
What cause the Error hardware 03130031-2F49 ?
Problem :
For errors 2618, 2F48, 2F49, 2F50, 2F51, 2F52 randomly occurring please follow the steps below.
Solution :
If the printer has the latest firmware installed (Ver. 1.25 or higher - iPF8300 Series), you only need to do the following:
1. Check if the Status Print or Print INF files indicate which print head experienced the error and replace it.
2. If the specific print head failure cannot be determined, replace both print heads.
NOTE: With the previous low level firmware installed, any printhead damage may have spread to other components. Upgrading to the latest firmware version prevents the other components from being damaged in the future. For the initial failures with the low level firmware, you must replace the other components that would have also failed.
Jun 04, 2014 | Canon imagePROGRAF iPF9000 InkJet Printer
200E freezes up
A 200e that locks up usually need a memory and a firmware upgrade. The original 200's only have 32mb of internal memory. The upgraded mini print board that is used in the 730 has 64mb of memory. This 64mb board was used in the 200 as a upgrade and this stopped the lock up problem. Also over the years Bernina has improved the firmware and this also cures the lock up problem. The latest and probably last firmware version for the 200e is version 5, also called the cutwork version. The easiest thing for you to do would be to take your 200 to a dealer and have them install a 64mb mini print board and also upgrade your machines firmware to the latest version 5. Also if you have loaded embroidery designs in your machine, remove them as they use up the machines memory. When you get too many designs loaded even if you have a 64 MB board in your machine you can still have lockup problems.
May 28, 2014 | Bernina Artista 180
Firmware version
Wireless routers contain built-in programmable logic called firmware. The firmware is embedded software that implements network and security protocols for that specific model of hardware device.Every wireless router ships with a tested version of firmware provided by the manufacturer. However, most routers are also designed to support a firmware upgrade process. This allows the manufacturer to provide enhancements to routers already sold. Manufacturers generally provide firmware upgrades as free downloads from their Web site.
Additionally, a few manufacturers (like Linksys) provide their firmware as open source code on the Internet. Programmers worldwide are free to modify and extend the code with new features for their routers. Several versions of this hacked firmware can be found on the Web, but the average homeowner should avoid these types of firmware.
The Firmware Update Process
You begin a firmware upgrade by downloading a binary file package from the manufacturer's Web site. After the package is set up properly on a PC, an administrator can launch the actual upgrade from the wireless router's administrative console. The router will stop functioning if the upgrade fails to complete. For this reason, manufacturers generally recommend an Ethernet cable be run from the router to the PC to ensure maximum stability during the update. Consult the router's product documentation for details.
Immediately after purchasing a router, check the firmware version to ensure it is the latest version. Firmware can be installed on a router at the factory several months before the router is sold.
Then, check the manufacturer's Web site occasionally over time for any new firmware upgrade postings. Each time a firmware upgrade is posted, the manufacturer will provide notes detailing the enhancements it provides. Feel free to skip an upgrade if the new version does not offer any interesting features. However, if a router is performing sluggishly, freezing unexpectedly or experiencing dropped connections, firmware upgrade often supplies a quick fix.
Dec 15, 2011 | NetGear Computers & Internet
Hi please tell me how to unlock nokia 6500 slide
you can try to check if theres any updated software/firmware for your 6500. you can check that from this website:
http://europe.nokia.com/support/download-software/device-software-update/can-i-update
then enter the code which is located at the back of your phone.
you can check the your current firmware by typing *#0000# from the standby screen
NOTE: PLEASE MAKE SURE TO BACK UP EVERYTHING BEFORE UPGRADING YOUR SOFTWARE/FIRMWARE
if it shows that theres a latest software version than the current version of your phone then upgrade your software using Nokia PC Suite. then it will reset your security code and settings.
Aug 22, 2010 | Nokia 6500 Slide Cellular Phone
I want the latest version update for nokia 7710 @ formating code
ASAP! It's well worth updating firmware, Go to the phone and enter *#0000# to check your firmware version and date
upgrade: 4.10.0 firmware upgrade
Jan 22, 2009 | Nokia 7710 Cellular Phone
Getting The WRE54G To Connect With The WRT54G
The WRT54G, WRT54GS, and WAP54G all must have the latest firmware versions available installed in order to connect with the WRE54G Wireless-G Range Expander. Here are the minimum firmware version requirements that you must meet: * WRT54G (all versions): at least firmware version 2.02.2 * WRT54GS: at least firmware version 2.07.1 * WAP54G (all versions) : at least firmware version 2.07 To Identify your WAP54G Version Number: To find out which version of the WAP54G you currently have, flip your Access Point over to look at its underside. Near the serial number label, near the Linksys© logo, you will see your model number and a possible version. Labels for the WAP54G version will look like one of the following: * WAP54G (no version means Version 1) * WAP54G ver. 1.1 * WAP54G v. 2 For WAP54G Version 1 and Version 1.1 Users ONLY: (if you have a WAP54G Version 2, you may proceed with the 2.07 or later firmware upgrade) NOTE: Before upgrading the WAP54G Version 1 and Version 1.1 models to firmware version 2.07 or later, make sure your Access Point?s current firmware is version 1.09.1 beforehand. The version 1.09.1 code performs an important OS upgrade for these versions of the Access Point -- it must be loaded before using later firmware.
Feb 16, 2006 | Linksys (WRT54GC) Router
XBOX
Yes, both Playstation 2 Online and Xbox Live have been tested and are known to work with both game consoles online. Do make sure that you are using the latest version of the routers firmware. To get the latest version go to http://networking.belkin.com and click on Firmware. Make sure you download both the firmware and the instructions on how to update the router. If you are already running the latest version then you do not need to perform another upgrade. To check to see if you have the latest firmware version open a web browser and type 192.168.2.1 into the address bar. Log into the router as instructed in the user manual. Once logged in choose Utilities over to the left and the choose Upgrade Firmware. It will tell you the current firmware version in there. If it is V1.20 or higher then you are OK.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Cameras Logo
26 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
