Question about KitchenAid Dishwashers
My KitchenAid dishwasher model # kudp01ilbl2 won't start. It is the first time we're trying to start it since we had our water heater replaced (three, maybe four days ago). Not sure how much that may matter. I tried turning off electricity to the dishwasher at the fusebox (overnight), but that did nothing. Normally, you just need to hit the start button and the washing begins. Now, nothing happens. The dishwasher is about six years old.
  • KitchenAid Master
  • 1,830 Answers
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 29 Answers
Posted on Jun 27, 2017
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 185 Answers
SOURCE: Noisy Dishwasher
has there been any hard objects such as fruit seeds nuts egg shells ect. is it doing it in all the cycles
Posted on Mar 28, 2008
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
SOURCE: Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Posted on Jun 12, 2009
SOURCE: Flashing "Washing" light on my frigidaire 1000 series dishwasher
Possible solution. I had the same problem of "washing" light flashing last year and now today. Warranty has been expired for awhile, so no harm in trying. What worked for my situation was removing the six screws for the back of the plastic control cover. Take of the plastic cover. There are are two connectors to the HANDLE with white and black wires. To be safe I would shut off the ciruit to the dishwasher. Safety first. Carefully disconnect and inspect the contacts inside the connectors. Do not insert any metal objects if you left the power on. I believe that the moisture from the dishwasher can degrade the connectivity. I cleaned the contacts with q-tips and re-installed. Be careful to not bend the contacts. If you had sound, you could hear my dishwasher running. Total cost is about three cents. I believe that the connectors do not full close when corroded, which prevents the completion of the circuit to the controlls. The flashing light indicates that the door is open, when in fact it is closed. Hopefully this will help someone. Semper Fi
Posted on Feb 06, 2010
Buttons on the dishwasher's control panel is not working. When starting a "normal" load, it switches to "clean" and does not start the wash.
Hello. Most likely, the humming sound you hear is a jammed drain pump which is activated immediately to pump out any stale or standing water below the level which you can see. Then, fresh, hot water enters the tub to start washing the dishes. I need the model number and exactly what lights are blinking--those blinking lights are error codes(combinations of 2 or more lights, one light blinking a certain number of times, then blinking again, a different number of times--ex 3 times, then 7 times) the lights blink a binary error code--thats why I need the model number to look up the code on the chart
Sep 10, 2015 | KitchenAid Dishwashers
I want to know what was the exact maker/model, part# of your unit
Jun 01, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Why does my Kitchenaid dishwasher model 8524569 run so long?
It is likely the heater is not working effeciently and takes a long time to heat the water to the set temperature. Try and run the rinse cycle and see if that takes much shorter as this does not need to heat the water. Please provide the full model number- xxx. xxxx or KUD..etc.
Apr 28, 2014 | KitchenAid Dishwashers
Shuts off mid cycle
it is likely the heater or thermostat are faulty. Try to run in short cycle like rinse which works on cold water.
Apr 11, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
Kitchenaid dishwasher KDC-18 works but the water does not get hot just cold. Any solution?
Dishwasher must be connected to a hot water line in order to work properly. Also, it often requires a good deal of time for hot water to make its way from the water heater to the dishwasher. If the dishwasher is located under the kitchen counter, turn on the hot water in the sink until it runs hot, then start the dishwasher.
Many dishwashers have a built in heater, but hot water should be initially fed into the dishwasher through the water inlet in order for it to perform properly.
Mar 17, 2013 | KitchenAid Dishwashers
My Kitchenaid dishwasher is not turning on. I hired a repair man who charged me $108 to replace the fuse. The dishwasher worked for a few minutes, but then failed before the cycle was over. He then said...
something is blowing the fuse==a direct short somewhere. I would never use that repair guy again, $288 later, dishwasher should work. just trying parts is not a repairman, its a parts seller. if you cannot find the short, not worth replacing parts. and obviously 288 almost buys a new dishwasher. good luck and call his boss and complain about the repair and ask for your money back
May 05, 2017 | KitchenAid 24 in. KUDS01DLSS Built-in...
I have a kitchenaid dishwasher modl # KUDIO01IL. Someone opened the door during a wash cycle and now the CLEAN LED is flashing. Tried pushing cancel and unplugging. No change. Any ideas/
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn't work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Nov 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Takes a long time to what? If the entire cycle seems to take forever, one suggestion is to make sure your hot water heater is turned up. Most dishwashers requires the water to be a minimum of 120 degrees before the timer will begin. If you are using a Sani-Wash cycle, then the water need to heat up to 165 degrees. The heater can only heat the water 1 degree per minute, so if the water coming in to the dishwasher is only 100 degrees, it will take an additional 65 minutes before it will even start the cycle. You can also make sure you get the water at the sink hot before you start the dishwasher, this will ensure the hottest water is going in (only fills for 90 seconds).
Jul 30, 2010 | KitchenAid KUDR01TJ Dishwasher
Clean light won't stop flashing, dishwasher won't start
if it blinks 7 times? ur putting too cold water in unit. if its 120 degrees then check heater assembly. if its good replace it with a heater kit comes with a board
Feb 06, 2010 | KitchenAid Dishwashers
Kud101 diswasher heater element
The dishwasher will heat the water to a temp of aprox 140deg if the heater is not working then the dishwasher will not shut off because it has to heat the water to a point where a thermostat will close during the heating time the dishwasher time stops advancing, also heater is used to heat the air for dry cycle
Sep 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
159 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
