Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
MANGNAVOX 19MF337B127 HDTV - SOUND WORKS FOR 10 SECONDS AND GOES OFF. ALL CABLE AND POWER CORDS ARE ON TIGHT. HELP
My LG LH40 47Inch screen shows logo then gos off
Main board fault. Contact any service technician, or the authorized service center for LG. The second said will be the best.
Gopakumar Gopalan Google
Apr 01, 2014 | LG 47LH40 47 in. LCD HDTV
My tv has no sound, not when cable is on or my xbox 360 is plugged in.
Try unplugging the power cord from the TV for 10 seconds then plugging it back in. This may reset the TV and resolve the issue.
-G33k
Sep 20, 2011 | Envision Monitors L26W761 26 in. LCD HDTV
My TV keeps flashing bright colours at me and not staying on the actual colour, no matter what channel I am on. Can you help me fix it?
if you have a cable box make sure your component/hdmi cables are in tight.if that seems fine try unplugging the power to the t'v for 10-20 seconds then plug it back in. hopes this works for ya.
Jun 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a 2006 Sony Wega 50 inch. set turns off after 10 minutes, green led flashes for 45 seconds and then set turns on. it repeats. is the power cord bad?
try to powercycle to reboot, check connections if tightly connected. advise cable provider (if any) to send signal to refresh if have cable box
Jul 21, 2009 | LG RU-60SZ30 60" Rear Projection...
No picture or sound on Mangnavox 51mp392H
check the power supply for loose solder
Jul 16, 2009 | Televison & Video
ViewSonic VX2235wm monitor looses power ...
I've not seen this problem on a ViewSonic but have on a Dell flat screen. The fix was the obvious one: the power connection on the back of the monitor was loose -- have you checked this. Also if the power cord is too tight it could be the problem. Other then this, it sounds like a short inside the monitor.
Hope this helps
Mar 17, 2009 | ViewSonic VX2235wm LCD Monitor
Popping noise
Our Sony (almost new) is experiencing sound problems. The sound go off and on about every 10 seconds. Cords appear correctly connected. It sounds as if its coming from the television.
Can you help with this problem?
Thanks,
Mike
Oct 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
