Question about Hunter Dryers
The motor will not turn any more. I can turn by hand but it will not turn with electricity.
  • 87 Answers
Your motor is to weak to start on its own, sorry to say but you will have to get a new one for no more then they cost.
Posted on Oct 03, 2009
2006 Amanti blower will not run and keeps blowing fuse. The blower motor turns freely by hand.
There is a short circuit on the B+ power circuit for the blower motor ! Your best bet would be to take your vehicle to a qualified repair shop ! Finding electrical shorts can be tough ,even for seasoned tech > There are videos on youtube on finding short circuits an basic electrical trouble shooting , how to read a wiring diagram ! You can find a wiring diagram at http://bbbind.com/free_tsb.html . Troubleshoot Car Electrical Problem .
Aug 14, 2016 | 2006 Kia Amanti
My ED56 won't start unless you turn the drum by hand why?
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Apr 28, 2012 | Fisher and Paykel Dryers
I need to replace the blower motor because when you turn it on it squels very loudly until it warms up. do you have a picture of exactly where it is located so I can see what I am up against?
Welcome to Fixya
Here's the procedure on how to replace the blower motor.
1 Turn off all electrical devices and turn the ignition key to the "Off" position.
2 Remove the battery's negative cable bolt with a wrench. Pull the negative battery cable off of the battery.
3 Locate the passenger side instrument panel insulator panel located under the passenger side of the dash. Remove the two panel retainers from the panel with the retainer pin removal tool. Pull the panel off of the locating stud and away from the dash.
4 Disconnect the panel harness clip by hand and move the harness out of the way of the blower motor. Unplug the blower electrical connector by hand. Remove the cooling hose from the blower motor by hand.
5 Remove the blower motor retaining bolts with a wrench. Lower the blower motor and fan out of their housing.
Thank you for using Fixya!
Dec 19, 2010 | 1998 Oldsmobile Intrigue
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
The drum will not turn, but turns easily by hand
have you checked the belt.
there is a small access panel on the lower left side of the machine on the rear you can take off and vie the motor and belt.
is the motor turning?
Mar 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Were is the heater blower on a 98olds silhouette in back of van on the left or right
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Remove the left hand side rear quarter access panel.
  3. Remove the blower motor electrical connector.
  4. Lift the tabs on blower motor and turn counter clockwise.
  5. Remove the blower motor.
To install:
  1. Install the blower motor and turn it clockwise until the tabs lock into position.
  2. Connect the electrical connector.
  3. Install the left-hand side access panel rear quarter.
  4. Connect the negative battery cable.
Nov 19, 2009 | 1998 Oldsmobile Silhouette
The electric motor comes on but the engine does
Is the motor turning? Only one fuse and the starter will not turn if it is bad. If the motor is not turning, make sure the belt is not slipping. If it is not slipping, make sure the engine will turn by hand. MAKE SURE KEY IS OFF BEFORE YOU PUT YOUR HANDS IN. If it seems free, you either have a weak battery or the brushes in the starter have worn out. I change at least 20 sets of brushes a year on Club Cars.
Aug 14, 2009 | 2002 Chevrolet Avalanche
Motor was running smooth new cambelt service ect,adjusted timming because could hear pinning on accelaration switched car off for one hour, while looking for an electrical fault on aircon turned aircon...
if you turned the motor backwards and then tried to start belt could have jumped this is a interferance motor which means the valves overlap the pistons ! you could have bent the valves.take it back to the person who did your timing belt
Jan 25, 2009 | Hyundai Sonata Cars & Trucks
Chainsaw electric motor jammed
Remove the chain, then see if it will turn over by hand. Does it have a chain-brake??? Frankster016
Oct 18, 2008 | Electric Chainsaw Sharpener
Dryers Logo
109 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
