Question about Ovens
Gas oven goes out when it goes down to low flame when door closes.
    Genius:
  • 1,341 Answers
Check your manual as some models that have a grill at the top requires the door to stay partially open.
Posted on Oct 03, 2009
I have a kitchenaid model kgrs505xss double oven. The flame in the bottom oven comes on and burns for a very short time, then turns off before the oven comes up to temperatures. What is wrong?
Any gas cooker has a thermocouple that keeps the gas valve open; if the thermocouple no longer generates current (which feeds the coil of an electromagnet) then the gas valve closes and the flame will go out. So check thermocouple. In normal conditions the voltage generate by the thermocouple is low but the current is high.
Nov 14, 2017 | KitchenAid Ovens
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
New world oven overheating
Presumably it is a gas oven?
It should light on a low flame then as the ffd warms it will come onto full rate, when it reaches temperature it should go down to a low flame, to test it set the thermostat to mk 6 and leave it on for 10-15 mins, if you have a glass door look and see if the burner is on low- if it is not then your oven thermostat is faulty, if it is over ten years old it is probably not repairable as parts are not usually available, If you still have the users//service manual there will be a 'shorts' 'parts list in the back listing the thermostat which will give you a part number , if you google that you should get an idea on price and availability.
May 11, 2012 | General Ovens
Single gas oven gas flame maintains heat until door is closed and then it goes very low.Any ideas?
the thermocoupler is faulty get a new thermocoupler and fit and it should be ok
Apr 21, 2012 | Ovens
My oven when i close the flame goes off
If the oven will light and work with the door open but flames out with the door closed, you have the air input blocked somehow. I know some people line their ovens with aluminum foil, but you have to make sure that you have the air flow.
Jun 03, 2011 | Bakers Pride BAK-DS805 Gas Single Oven
Flame does not always stay on after ignition, sometimes it does and when it doesnt you open and close the door for re- light ?
Opening and closing the door will reset the ignition sequence, do not do this repeatedly as you could cause a build-up of unburned gas in your heat exchanger and damage it. Instead verify that your ignitor is glowing, then see if the burner lights and make sure the flame carries all the way down to the bottom of the burner. If the flame stalls halfway or doesn't make it all the way to the bottom in 4 seconds after 3 attempts you will experience an ignition lockout, a safety feature built into your ignition module. If this is the case your burner needs to be cleaned and serviced, have a professional do it.
If the flame is reaching the bottom of the burner but still going out after about 4 seconds then you have a dirty/broken flame sensor. You can attempt to clean your flame sensor by removing the screw that holds it into the burner. With it removed it will look like a metal rod going through some ceramic, clean the metal rod part with a wire brush or emory cloth (fine sandpaper). Replace the flame rod and try again and see if the burner stays on this time. If it still goes out your burner needs to be serviced by a licensed technician.
Feb 11, 2011 | Baxter BXA2G Stainless Steel Gas Single...
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
Garland deck oven
your gas valve may be freeflowing you must have this checked right away
Sep 29, 2008 | Garland M-1 GL Gas Single Oven
Ovens Logo
61 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
