Question about RTO M-D Building Products Carpentry & Construction Box Beam Level 48"
How to make a 1.5 x 7 inch wooden disc with common tools and can't leave any holes in the surface of the disc. Any sugestions ?
  • wdfour Feb 01, 2010
    I found that if I use a bigger lathe that has jaws large enough it will hold the block of wood and if I make it at least 2 or more inches thick I can make my disc and can remove the excess wood by turning it. This will give me the most accurate form I need.
  • 557 Answers
Use a 3.5 inch string and a pencil to draw the circle and cut with jig saw.
Posted on Oct 03, 2009
What is regulation height for a dartboard
Dart Board Measurements: Standard height from the floor to the bullseye on the dartboard is 5 feet 8 inches, while the oche (distance between the front of the board and the toeline) should measure 7 feet 9.25inches.
Nov 01, 2016 | Grilling
How to take out aerator for cleaning
doesnt the bottom of the tap end unscrew as the the jet thing is behind this
Dec 21, 2011 | Hamat 3-2861ST Everest Pull-Out Kitchen...
My dvd is broken, i think my son put another dvd while another one is inside... can you help
You will have to disasemble DVD player to retrieve DVD discs. On some players there maybe a small hole on front or side to dislodge discs. Put a wooden or plastic pin in hole to release discs.
Good luck.
Jun 15, 2011 | 2005 Ford Freestyle
Details dimensions of clothes washer for the bleends at the back for ducting porpose.
Factory-supplied
equipment
There is a packet of accessory parts supplied with your washer. Check that all the accessory parts supplied for your model are there. If any parts are missing contact
your dealer immediately.
Inside the drum
Water supply hose for cold water (blue marking).
Water supply hose for hot water (red marking).
Water drain hose.
A bag which contains
Covers to be placed over the holes for the transport bolts (after removing them).
Clamp for drain hose.
Wrench for levelling.
Elbow for attaching the drain hose, e.g. to a sink.
Depending on the type of connection, the following may also be required
Y-connector (can be obtained from any hardware store) in case there is only a cold water
connection available.
Any residual moisture inside the drum is due to the final testing which every washing machine
undergoes before leaving the
factory.
On the rear of the appliance
Power cord with plug.
C = cold water connection
H = hot water connection
Useful tools
The following tools are helpful
Box cutter.
Flat head screwdriver.
Closed wrench (1/2"/13mm).
Bubble level.
Dimensions
a = 27.0 inches (686 mm)
b = 30.7 inches (780 mm) c = 37.0 inches (940 mm) d = 16.0 inches (407 mm)
Door opening angle 180
Approx. weight = 220 lbs (100 kg)
Installation area
DANGER
Never ground the washer to plastic plumbing lines, gas lines or hot water pipes.
Appliance stability is important, otherwise the washing machine could "walk" during the spin
cycles.
The installation area must be solid and even. Soft floor surfaces, such as carpets or surfaces with
foam backing, are not suitable.
If the washing machine is to be installed on a weak wood floor consider the following
0 If possible, place the washing machine in a corner of the room.
0 Screw a water resistant wooden board (at least 3/4" thick) to the floor.
0 Secure the feet of the washing machine with holding brackets. Order the holding brackets (set)
from Siemens Customer
Service (WMZ 2200).
Pedestal Mounting
If mounting the washer on the Siemens pedestal (accessory
no. WZ20395) follow the instructions supplied with the pedestal.
if Install pedestal prior to removing transport bolts.
Closet
If installing the washer in a closet,
observe the minimum distances according to the following table
Minimum Installation Clearances
Closet
Sides 1/4" (6 mm) Top 12" (305 mm)
Rear 2,5" (64 mm) Front 1/4" (6 mm)
Ventilation
Top 48 sq. in (310 sq. cm),
Bottom 24 sq. in (155 sq. cm)
Jan 03, 2011 | Siemens WFXD5200UC Front Load Washer
Cannot get the rear discs off my 2000 rodeo for a brake and disc change. everything is off, they will not slide off.
Check the specs,sometimes even though the front rotors slide off ,the rear rotors may be of a different design and you may have to take out the center bolt to get them off.If thats not the case then you may need a rotor removal tool.There should be a couple of threaded holes somewhere on the throat of the rotor,the tool will bolt into those holes then there will be a center bolt that you will tighten against the bearing bolt,as you tighten this up it should pop off the rotor.
Jul 14, 2009 | 2000 Isuzu Rodeo
My 2year old toro 6.0 lawn mower wont work i just took it out from the shed, it was in there during the winter and now wont work. it worked perfect before why is this not working someone told me its debris...
did you burn all the gas out at the end of year last year if not bad gas will leave deposits in the carburator.here is a simple sugestion drain any gas out of it thats in it .put fresh gas in it and 2 table spoons of marvel mystery oil in gas tank you can get it at any auto parts store crank it untill you are sure fresh gas oil mixture is in intake wait an hour and let the fresh gas\oil mix do the work.pull plug dip it in fresh gas put plug back in and try to start it this often works if it dont you could have leaves .dirt .rust .or debris on surface of flywheel ,or a bad sheer pin on flywheel the sheer pin is whar times the engine on most small engines good luck i hope these sugestions help
Apr 29, 2009 | Toro Lawn Mower With Toro Power Tools
Elantra rear brake replacement
hiya the rear disc brakes are as front disc brakes auto adjusting however the rear brake calipers pistons have to be wound back into the caliper to enable new pads to be fitted if you look at piston you will see they have either slots or holes in the surface this is for a sutable implement/tool to fit and then turned clockwise whilst pressing piston as you wind/rotate it back into caliper for your info there is a tool made for this purpose made by draper or seeley tools which makes job easy diy and cost £9--99 uk and can be bought from most auto stores ? however it is possible to manage with the spanner with horse shoe open end commonly supplied with circular hand saws the spanner is the one used for replacing blade? i have used this in past with success but now have the expensive univesal tool for the job hope this helps?
Dec 04, 2008 | Hyundai Motor 2002 Elantra
Digger support
Search local home and garden stores to find a post hole digger. Many department stores sell post hole diggers too. A local greenhouse or tractor supply store is also a good place to look for a post hole digger. Decide on he type of digger you'll need for the job. Although post hole diggers come in different sizes and types, they generally dig the same size hole. Know that it takes a lot of strength to dig holes with a post hole digger, but there are a diggers available with special features that allow someone not quite as strong to use the digger too. Pick up and examine the different post hole diggers while you're shopping. Compare the feel and weight of the tools. Pretend to dig holes and see how it handles. Compare the features and designs of different post hole diggers. Most are manufactured from fiberglass or steel, but some have a different shaped handles for specific digging jobs. Determine if you'd rather have a fiberglass handle or a wooden one. Fiberglass is lighter and more resistent to sun damage than wooden handles. Select a post hole digger based on your preferences, the job required and who'll be using the tool. Plan to spend more on a post hole digger that's made from steel or for heavy duty use. The range for a post hole digger is generally under $50.
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Masonry Jointer Usage
While the final effects of a stone or concrete wall are stunning, the work to make it beautiful is time-consuming and difficult. Tools are very important in masonry work. Having the right tools for a certain job make all the difference. Jointers come in many different sizes and shapes. Learn the various types and how to use them and you can make quick work of a difficult task. Use an e-jointer for narrower spaces between the stones. There is no handle on the e-jointer, making it easier to smooth and shape the joints between the stones. Whenever your hand is closer to the surface, you can exert more control. Get a bead jointer for raised masonry bricks. These jointers come in two sizes, 1/4-inch by 5/16-inch and 3/8-inch by 1/2-inch. They are small, strong, simple tools that can chip off the excess of a joint that is sticking up off the brink. You do not want to make a deep joint between raised bricks. Change your joint tool to a brick masonry mortar joint raker tool if you are making your project from rougher materials, such as adobe brick or split stone. This tool has many more grooves, which will fit in various sized joints. Turn it on the end for narrow joints and use the curved notch for more intricate patterns between the stones. Switch to a grapevine mortar jointer for very clean lines between the bricks. This tool is used primarily for a colonial look, which is even and measured. Your can get this jointer with a wooden handle for a more even grip.
Aug 27, 2008 | Delta Machinery Delta 37-658 Jointer...
RTO M-D Building Products Carpentry & Construction Box Beam Level 48" Logo
101 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Tim Venetis
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
