Question about Maytag MSD2454G Side by Side Refrigerator
MODEL MSD2456GE WATER ACCUMULATES AND BECOMES A MOUNTAIN OF ICE I
In addition, the water despenser isn't working. The ice despenser is working fine. Do I need to replace the pump?
  • Maytag Master
  • 19,396 Answers
this fridge has no pump, but several outlet valves regulating water to icemaker and dispenser.
The first thing to do is allowing the fridge complete defrost. This will fix problems caused by ice inside water lines or outlet valves.
If that does not work, the first part to test is the main water valve, that is sending water to both icemaker and dispenser. This is located behind the refrigerator. The water valve is about four inches long.
Here is the part.
You can find hints and instructions on how to replace the valve here: 'Do-It-Yourselfer' stories about installing this part
The outlet valve is tested checking if it is opening and closing, and if there is continuity at the solenoids contacts (the ones in the valve). If the valve is fine, check the outlet valve located inside the fridge, below ice maker assembly: SUB 12001892 (Dual Outlet Water Valve Kit) This second valve is not present on all fridges from same model , but sometimes is replaced by an Y connector.
Before replacing valve do a complete defrost, and inspect water lines for blockage.
Regards.
Posted on Oct 03, 2009
Kenmore 106.56666500 ice maker not working
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 31, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
Hello, I replaced the filter MSD2456GE and I wanted to now how long does it take for the ice or water to start?
you can start despensing the water right away, but dont drink it, after you replace the filter dump at least 2 gallons of water before you start drinking it, and the ice normaly takes 24 hours to make the first full bucket of ice, dump two of those before you use it!!
Jan 09, 2011 | Maytag MSD2756G Side by Side Refrigerator
WATER LEAKING OUT OF FREEZER DOOR
The defrost drain hole in the bottom of the freezer has frozen over. Turn off the fridge. Remove the shelves and bins. Remove the rear panel of the freezer. You will see ice on the bottom rear of the freezer. Use a hair dryer to melt the ice,especially in the drain hole once you get through the surface ice. Once the drain hole is clear,pour a cup of hot water through the drain hole followed by 1/4 cup bleach. Re-install your parts and turn the fridge back on.
Sep 21, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
Ice and water don't work
This could be several reasons, water valve on back not working, thermostat in ice tray not working, heating element below ice maker not working, we just need to start with the dual water valve on back first. The side that feeds the ice maker needs the solenoid checked. I am ready to help you solve this, Let me know, Thanks, Sea Breeze
Apr 16, 2009 | Refrigerators
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Maytag MSD2454G Side by Side Refrigerator Logo
80 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
