Question about Dell E173FP 17" LCD Monitor
The monitor displays the screen then goes black. For example, I turn of the monitor off and then back on. I will see the screen for 1/2 second then it will go black.
  • sglick Oct 03, 2009
    Wow - Thanks for your prompt, very clear response. I have done all of the above and the problem continues. I have switched the cable with one that works with a different monitor - that did not solve the problem.
    I have connected a different monitor to the computer and the new monitor works.
    I have attached the bad monitor to a different computer and have the same problem.
  • 21 Answers
Hi sglick - you will need to do a few simple trouble shooting steps to pinpoint the problem, as this can be cause by several different things.
Follow these steps and reply back with your findings: 1. Unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor. 2. Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet. 3. If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad. 4. Disconnect all connected devices except the mouse, keyboard and monitor. This includes thumb drives and camera-type memory cards from card reader slots. With the devices disconnected, restart the computer. If the computer starts and the monitor now displays a picture, a device is preventing the computer from starting or sending a proper video signal to the monitor. Update the BIOS to resolve this issue.
If doing all of this doesn't change your issue of no video after seeing it pop on, try the monitor on a different computer/laptop, and if you have one, a different monitor on the system with the problem.
Let us know what you find following these steps and we can figure out what to do next. -Trev
Posted on Oct 03, 2009
Testimonial: "very helpful"
  • Trevor Sawyer
    Trevor Sawyer Oct 04, 2009
    Ugg... I was hoping that just some re-seating of cables, or swapping out of cables would do it. I think you know now that it is a monitor failure. Since it seems to do okay with receiving the video signal for an instant, it is probably the power board failure in it. If still under warranty, contact support, give them details of the troubleshooting steps you performed, and they will take care of things. If not under warranty, time to find a sale on a monitor!
    I wish we could have "fixed" everything for you today! Sorry it turned out this way.
    -Trev
Posted on Oct 06, 2009
tantong
  • 138 Answers
SOURCE: Monitor displays
I used to repair LCD monitor from Dell. It works for me. You might be using these following steps to examine what wrong with your monitor. After you turned PC on and monitor stopped working or went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image (Start menu), there will be a minor problem. This is because of CCFL lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 18, 2008
SOURCE: Monitor screen goes out (black) 2 seconds after turning on
Your site is extremely misleading and fraudulent. I was under the impression that I would at least get a hint at what might be a problem instead of you folks making me wait to get a money for something answer that you could have displayed on your main page. Places like yours have no place on the internet and I'm going to find out what I can do to report you.
Thank's for nothing
Posted on Jan 17, 2009
shredivya
  • 71 Answers
SOURCE: monitor does not display picture.
Plase update Display/graphics driver.
If you have a external monitor try plugging into notebook, if the external monitor works fine, you can replace the display.
>Check in safemode>If its stays for long time, it could be an issue with Virus.
>Check in BIOS as well
>If the external monitor is also acting in a same way, you may have replace the system board
Posted on Jun 30, 2009
budmrtn
  • 11361 Answers
SOURCE: Hello ...I have a medion
Bad power supply due to bad DC filter caps, failed backlight inverter board due to failed MOSFET, transformers, lamp assemblies. You need to troubleshoot it.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 24, 2010
budmrtn
  • 11361 Answers
SOURCE: Westinghouse monitor will display for
It can be bad caps, bad MOSFET, transformers, backlights assemblies.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed WESTINGHOUSE and other monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 22, 2010
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
The display flashes on for a second or two, then goes black. This happens each time it gets a new type of signal. So for example when booting up the PC it displays the video card logo for a second, then...
Bad caps can look normal but can have high ESR, you also need to check the DC voltages. You can also have bad lamp assemblies, etc.
Make and model will help also, you can look for service manual here: www.elektrotanya.com
Nov 29, 2010 | Samsung Computers & Internet
Hello ...I have a medion monitor ... recently I turned on and blue light indicator flashed but no visual display.. today I turned on computer .. my windows desktop displays for 1 to 2 seconds and the...
Oct 23, 2010 | Medion 6 Drawer Cabinet Workbench 17 inch...
Monitor comes displays Acer logo and goes black after 3 seconds, with indicator light still green.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Oct 18, 2010 | Acer AL1916W 19" LCD Monitor
Hello Sir, I am using DELL E173FP LCD monitor. My CPU absolutely fine I see initially booting thing on my monitor display then it gets black. I can hear starting sound of Windows XP, that too is fine. When...
You might need to change the screen refresh rate. Go do Control Panel> Display> Setting> Advance, choose 60 Hz. In order to make your Monitor able to display, restart the PC, press F8 on the keyboard frequently upon splashing ( 1 or 2 seconds after PC restarts). Select enable VGA mode by pressing up arrow of the keyboard> press enter. The display should look bigger, then you can start adjusting the screen refresh rate to 60 Hz
Apr 09, 2010 | Dell E173FP 17" LCD Monitor
Monitor cycles on and off. There is a display, but only shows for 1/10th of a second. Its a image flash, then black screen, wait for one minute, then it tries to turn on again.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Monitor went black in seconds
oboy, One thing to try is the flashlight test. and get backto me with your findings. Tell me, does this lcd show a nice display only for 1-2 seconds and then a black screen when connected to a fully booted PC with Windows desktop displayed? Shine a bright flashlight 1-2 inches from panel and tell me if you see the WINDOWS START Button at lower left of screen even though screen is black! Get back to me if you can. I'm louie12fix on fixya or lmistyrel @ aol.com BYE for now.
Apr 04, 2009 | Niko 1920W Monitor
Thank's for nothing
Jan 16, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
Dell E173FP 17" LCD Monitor Logo
559 people viewed this question
Alun Cox
