Question about Acer Aspire 9300 Notebook
Graphics card is not functioning properly. Control panel says "card working properly"
  • mpawlak908 May 11, 2010
    How is it not functioning properly?
    How is the card not functioning properly? You might hook up external monitor and see how the graphics card performs.
I recently bought an Acer 5742G notebook and I keep on getting a pop-up saying my video card is not compatible with Direct3D. Can I update my video card driver? if so, how?
You should be able to update your driver for the graphics card. If you can, open the Nvidia control panel. Then, if you look around in the menu, you should see something along the lines of "Check for new update". Just click that and it should lead you along to update the driver. If you can't find the Nvidia control panel, or for some reason the "Check for update" isn't working, you can go to this link to get updated drivers for Nvidia graphics cards. They even have an auto-detect graphics card feature.
Download Drivers
Dec 18, 2012 | Nvidia GeForce FX 5500 Video Card Graphic...
Display drivers wont work
Dear,
There are two points.
1. Ensure that you are downloading and installing the correct driver for your graphic card.
2. If the fist condition is fulfilled then unplug the graphic card and check the system with the built in graphic card in motherboard and install its driver and get its functionality. When you are ensured that system is working with its own built in graphics then plug it again properly and install the driver. Ensure the proper plugging of your graphic card. Sometimes improper plugging of card cause this issue.
The second step will confirm the two things. one that your motherboard is functional with its own card and the reason is extra graphic card plugged in slot.. and the 2nd is that the card itself causing the issue not the motherboard and the issue was replugging...
best of luck...feel free to ask more...
Mar 06, 2012 | Computers & Internet
Problem is my graphics card stopped working... My question is, what is the best graphics card to replace it? I'm sending this message via a PC from a library. I await your response as soon as...
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly. Hope this helps
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also
Apr 16, 2011 | Power Color R96L-SC3 PowerColor 9600 SE...
Why my computer did not detect sound.. even if i check the control panel sound volume and mixer working properly.. i try to install sound card same result...
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 16, 2010 | ASUS 90YAA0C00UAN00Z Xonar Essence STX...
Hello, i have a Fujitsu A6120 laptop and the options for adjusting brightness (thru control panel and manual adjustment by key-function) are not working. the brightness is just set to maximum. I?d like to...
Either adjust them with your graphics cards control panel(right click desktop and screen setting should be there, or from the control panel)
or adjust it through the power options menu in control panel
Jul 10, 2010 | Fujitsu LifeBook A6120 Notebook
Second monitor detected but no signal?!
Try holding the function key ( fn) and pushing the F4 button. This very well may fix your problem.
Sep 22, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Find diver
Please got to the link below & update you're Radeon X1300Pro.
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp.
Go into control panel & uninstall any other ATI software before installing the unpaded software.
Enjoy!
Mike
Jun 02, 2008 | ATI RADEON X1300 PRO, (256 MB) PCI Express...
Amilo laptop ati graphics
Test it in another computer - if the same happens then you may need to replace the card.
As regards working "on cam" do you mean that HIS screen now works properly or do you mean that others can see the image clearly on their computers. If the latter, then it still looks like a dud video card.
Have you gone into Control Panel - Display and checked the settings? I don't think that there are any settings that would create the symptoms though.
Good luck.
May 08, 2008 | ATI Mobility RADEON Graphic Card
D3D malfunction
ATI does not like drivers installed over top of it's self. Weird I know. So uninstall through your control panel. If the uninstall fails download and run.:
http://searchna.ati.com/promosearch/?site=us-en&la=en&qt=cat-uninstaller&selectsite=ATI&sp_a=sp10039240&sp_p=all&sp-x-1=col&sp_f=ISO-8859-1&sp_q=cat-uninstaller&Search.x=9&Search.y=8
After a reboot install the new driver & Catalyst control center.
Jan 02, 2008 | ATI RADEON 9250, (256 MB) PCI Graphic...
Graphic card
i think that when you installed xp the windows generic nvidia driver has installed and is now not looking for any more upto date software, you will have to go to device manager in control panel and go to hardware tab, then devices and then go down to the graphics controller/adadpter line, right click and select uninstal. Restart the pc, but this time when the driver tries to install make sure that you select manual and not automatic then point the pc in the direction of the folder where you have the graphics driver residing on your c drive.
Aug 26, 2007 | Nvidia GeFORCE 4 MX440SE / 4000 / 4X DDR...
Acer Aspire 9300 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
