Question about Refrigerators
Evaporator coil freezing.
I have a Westinghouse side by side wse6070sa for the Australian market so not sure whether you will find this model on the US market. I have had it for just over a year and recently I started to notice that the freezer temperature alarm would go off and the freezer not staying cold. I had read a few posts and decided to have a look at the back panel of the freezer and realised that frost was forming. I then opened the back panel and the top part of the evaporator coil has frosted over. I have tried to defrost it with a hair dryer and then plugged it back it only to find that after 4 hours of operation that the freezer temperature alarm to start again.
I am not sure how to diagnose the problem. I have read that the control board controls the defrost process but how do I know that it is faulty? How do I know the thermostat is problematic? How do I know that the heater is faulty?
Would really appreciate some help!
Thanks
  • hihai2003 Oct 05, 2009
    Hi Milten,
    I just left the fridge to defrost for a day as the beeping was getting annoying.
    Checked the fan and it appears to be working using the trick that you said.
    What else should I check?
  • milten1
    milten1 May 11, 2010
    check to ensure the fan is working properly
    you can do this by holding the door switch closed
    you should hear the fan aftger a few secds, if you can visual view this it would be better
    President:
  • Refrigerators Master
  • 1,922 Answers
Sounds like either you need to thoroughly clean the evap coil, then restart and see if you hear a gurgling noise inside unit and if coils begin to frost again, then you could be low on freon/refrigerant
Posted on Oct 05, 2009
Westinghouse fj383
ne of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them
Dec 10, 2013 | Freezers
Westinghouse Fridge/freezer RJ340M. Not freezing cold.
Could be several problems, it may have a leak in the coolant system, the compressor may be bad, or the control system may be malfunctioning.
Mar 17, 2013 | Refrigerators
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Wawwwwtewwwwwar
Hi!!
Make sure drain hose is not clogged up. Check evaporator fan, (small fan in freezer compartment). it should come on after door is open a couple of minutes. Feel air vents in fridge side for a stream of cold air, if none or too weak, remove back cover (where fan is) and check for frozen evaporator coil. If evaporator is frozen, air can't circulate thru unit, keeping fridge side from cooling and freezer side below freezing point.
If this is the case, unplugg unit from power outlet, and use a heat gun or hair dryer to melt ice, make sure all vents are clear.
Once the evaporator coil is free of ice, dry freezer, replace back cover and plug unit back on. Check temp. settings, should be about 1/3 of the dial range. If necessary, make additional adjustments every 24 hrs.
Don't forget to rate this post!! Good Luck!!!
Jul 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Frigidaire central unit freezing up leaking
The coil freezing can be caused by a couple of things. 1) Not enough air flow over the coil or 2) A low refrigerant charge. First make sure that the indoor fan is running. Then check your air filters and make sure your evaporator coil is clean. After that you can get the refrigerant charge checked. The lower the refrigerant pressure is, the lower it's boiling point is and when it gets below 32F then the evaporator coil and usually the low pressure line freeze up. The leaking you were talking about is probably from the ice melting. Hope this helps.
Jun 06, 2010 | Frigidaire Heating & Cooling
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer not freezing
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 11, 2009 | GE Refrigerators
Evaporator Coils freezing.
Hi, The most common problem is the defrost heater. It is attached to the bottom of the evaporator coil in a bracket.
If you have a meter, you can remove the element from the coil and take the two wires off. Checck the post on the element that the wirea attach to for continuity. If the element is good, it will have continuity to it. If the element is ok, check continuity on the bi-metal switch attatched to the top of the evaporator coils. It too must have continuity to be ok and it needs to be tested while still cold.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 20, 2009 | GE GSH25KGPWW / GSH25KGPBB / GSH25KGPCC...
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Samsung fridge RS2545SH every 7 days freezes fridge coil.
no thermostat in this model but there are thermister it is also on the evaporator (yellow wire)
Aug 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
223 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
