Question about Maytag Ovens
My power went out last night. now my oven display
My power went out last night. now my oven display is not coming on. the oven light works and the top burners work. i have tried holding all the buttons for a period of time to reset, nothing works
  • 10 Answers
SOURCE: AEG Oven
try setting the clock, it may be automatic
Posted on Mar 22, 2008
SOURCE: Amana gas range bake burner does not heat
AMANA GAS RANGE
MODEL #ARG7301WW P1143323NWW
SERIAL: 9710232146
Hi Tamiw and oh Mighty Guru Text,.
I had the same problem with the oven not emitting a flame from the burner, but at the same time- the ignitor lit up and heated the oven enough to say it is 'HOT'.
It seems to be an intermittent problem';sometimes it emits a flame while other times I would wait 11 minutes with the dial set to 400 to emit flames.,
Detailed description of PROBLEM and steps I have already taken:
The Ignitor always turns on, and lights up.
1. After the initial cleaning of the burner vents with a coarse bristle cleanibng brush, I turned the oven dial on and everything seemed to be working fine. ie: ignitor turned on, blue flames came out of the burner and maintained a constant temperature.
Then,-after I had performed a "self-clean", to see if this feature would now work, it did! I used the oven for bake a few hours later......
The same symptom ocurred, the ignitor went on, but no flames were observed, YES, there was heat coming from the oven, but NO flames coming out of the burner mechanism:
The Ignitor turned on, but no "flames" were observed. Heat was given off from the glowbar, but no flames. I did NOT smell any gas, only what an inside of the oven smells like after cleaning.
From my records, I had replaced the thermostat about 4 years ago.
Today, I tried this again, and sure enough the ignitor lit up, and the burner was emitting blue flames. But when I put the "FLAME SPREADER" back, and turned the oven OFF, then on again to bake cookies, the oven didnt seem to heat up completely.
Could this be intermittent? or Could the flame spreader hamper the burner operation? (Earlier when I loosened the nut on the flame spreader the bolt broke. I tried to replace with another nut, but the bolt/screw was too short for contact.) Could this contribute to the problem? Does the flame spreader need to be tightly screwed for the burner to function correctly?
One thing I am noticing, is that it takes LONGER for the flames to come thru (than the average 90 seconds)
For example: Ten minutes ago I set the dial to 350. 5 minutes went by, and no flames, then set the dial to 450 after ten minutes oven was hot, but no flames?
I THEN SET TIMER FOR ANOTHER 5 MINUTES, AND 1 MINUTE LATER THE FLAMES TURNED ON. Total preheating time for flames to come on today = 11 minutes.
I have a "MULTIMETER" from DIGITEK Model # DS830B+ This should work to see the amperage, but I dont remember how to test it! the MAX OHMs are 2000, MA 200 Max, 500V
http://www.digitek.com.hk/
Can I use this to test the current? How would I do this?
Lastly, HOW DIFFICULT IS IT TO CHANGE OUT THE IGNITOR> Meaning do I have to shut off the gas as well as the power circuit?
Ok, hope this helps.
Thanks again,
Callie T
Posted on Jul 19, 2008
SOURCE: TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Posted on Oct 09, 2008
scottowa
  • 87 Answers
SOURCE: Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Posted on Mar 04, 2009
  • 44 Answers
SOURCE: Oven elements do not heat?
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
Posted on Mar 28, 2010
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! info@fixyourboard.com
Jun 05, 2017 | Jenn-Air Ovens
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
My oven display is beeping and blinking 'PBR' on the display. What does that mean?
I had this same problem last night.. I have been having problems with the oven shutting off on preheat.. That sort of stopped. Last night lost power to the house. When it returned the oven was beeping and flashing PBR. I turned off the breaker for a few mins. last night and it returned. It was bugging me so much that turned it off the whole night. Woke up this morning turned the breaker back on and it stopped. I don't think this is the total solution. I am thinking that eventually I am going to have to replace power board in this oven. Hope it works!
Sep 23, 2009 | Jenn-Air Ovens
Whirpool Accubake Control Panel
try turning power off and wait 10mins and see if it resets.
Sep 14, 2009 | Whirlpool RBD305PD Electric Double Oven
Mar 04, 2009 | GE Ovens
Oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
AEG Oven
Mar 22, 2008 | AEG B2100-4 Electric Single Oven
Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Nov 30, 2007 | Whirlpool GBD307PDS Electric Double Oven
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Ovens Logo
53 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
