Question about Kenmore Refrigerators
Got power but neither side cools,cleaned condenser that didnt work either.
  • 1 more comment
  • mike irland Oct 03, 2009
    the compressor seems to be running,but no cooling on either side. thanks mike
    the compressor is running but is not cooling.thanks mike
    how do i go about checking thermostat on a kenmore model #106.53532300. thanks mike
  • 855 Answers
If it has power check and see if there is power to the compressor. If there is and it is not coming on the compressor could be bad or there may be a freon leak causing it not to cool down. If the compressor works and freon is ok the thermostat could be the problem. You have to check one thing at a time.
Posted on Oct 03, 2009
I have a westpoint no frost delux tropical refrigerator that is not cooling on the fridge side and is not freezing on the freezer side. I cannot regulate the temperature on the right side as it stoped
Your refrigeration cycle has an evaporator inside the freezer section and air is blown as necessary to keep fresh food side cool. If neither side is cooling, you have most probable problems with the compressor not turning on. Some of the first things to check is pull the refrigerator and locate the condenser coil. Some of the coils are manufactured inside the sides of the refrigerator. If you have an external condensing coil, check to see if the condenser fan is rotating and the cleanliness of the coil. I have seen coil so dirty, no heat can escape and causes the compressor to overheat and the internal inherent motor protection opens and turns the compressor power supply off. After cleaning the coils and checking the proper operation of the condenser fan, allow the compressor to cool before plugging back on and turn the thermostats in both compartments to about 5 on the thermostats. You will know if the compressor starts if the smallest line coming out of it starts getting hot to the touch (be careful the line can get hot enough to burn your fingers) and check to see if the condensing fan operates. If these two things check out your refrigerator will start working again. If either of these two do not work, it will help determine which needs repaired or replaced.
I had one customer who had problems similar to your problem and found the breaker feeding power to his recepticle had tripped. Try plugging in an electrical device to the plug in to see if power is available if you do not have a multimeter. If no power, check breaker panel for tripped breaker. This was his problem. His was caused by trying to plug in to many loads on this one circuit thereby tripping the breaker which was rated at 15 amps.
Any further problems than this need to be analyzed by a refrigeration tech.
Hope this helps.
Oct 24, 2014 | Refrigerators
Repeat, corrected model number
Try unplugging the fridge and replugging it in. On this model if it doesn't cool, the display/temperature reading for the unit may start beeping like crazy. Resetting it sometimes fixes this. If you hear the compressor motor kick on, and it doesn't cool within 24 hours, your fridge will need a major repair. If it doesn't turn on at all, you may need a less expensive repair.
Nov 27, 2013 | Frigidaire FRS3R5EMB Side by Side...
Uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Is the condenser fan running? Is the condenser clean? (condenser is the "radiator like" coil outside of the ice box. It cools the hot refrigerant.
Sep 07, 2012 | U-Line Icemaker
KSBP25FKSS00 Kitchenaid refrigerator doesnt cool enough, changed the condenser fan motor and it didnt work.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 10, 2010 | KitchenAid KSBP25FKSS Side by Side...
GE Side-by-Side Fridge only gets slightly cool at highest setting. Won't freeze water.
Have you cleaned the condenser under the frig?
While you are looking there look to see if the condenser fan is running with the compressor.
If the condenser has been blocked for very long or and the fan is not working there is a good chance that that the compressor is bad. Just clean the condenser and hope for the best.
Aug 04, 2009 | GE Refrigerators
Fridge and freezer do not get cold but unit has power
Check the freezer fan to ensure it is operating. If it is and there is at least air movement, maybe cool, but not cold, first thing to check is the condenser coil located either at the rear bottom or front bottom. Make sure it is clean. Dust/dirt can clog the condenser preventing the unit from rejecting the heat. Same as with your central a/c. If the condenser gets dirty/plugged, your a/c will stop cooling. Other possiblity is the compressor is not operating. You should be able to hear it operating, will sound like a low hum with slight vibration. In the event the compressor is not operating, unplug the refrigerator, gently place your hand on the compressor, (it will be found in the rear bottom) to determine if it is warm, hot, etc. If it is hot, leave the refrigerator unplugged for 10-12 hours to cool. There is a thermal overload within the compressor to shut it down in the event of overheating. While the refrigerator is unplugged to cool, make sure the condenser is clean. Most causes of compressor overheating are related to a plugged/dirty condenser. Let me know if this helps.
Richard
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer and fridge not cooling well i clean the condenser fan
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
,.f
Mar 13, 2009 | Kenmore 53642 / 53644 Side by Side...
Side by Side Kenmore Elite
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
if this helps please vote me a fix ya
Jul 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
23 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
