I need a power cable for a combo52x external dvd player-aopen player
I lost my power cable.
  • 36 Answers
Does it look like this?
http://www.amazon.com/Memorex-COMBO-CDRW-DVD-32023268/dp/B0001F1ZVM
What kind of power cable does it use for power? Can you describe it?
Posted on Dec 21, 2007
External connextions
The only external connections the AOpen F1713 LCD monitor has, according to my sources;
1) Power Port (Connection) for the power cable
2) VGA port:
This is an example of a VGA connector,
VGA connector Wikipedia the free encyclopedia
On the upper right of the linked page you'll see a VGA connector in blue. Scrolling down a little, under the subheading - Cable quality - you'll see an example of a VGA cable.
The screen resolution is 1280 x 1024
If this is not the solution you seek, or if you have additional questions; please post back in a Comment.
Regards,
joecoolvette
Jan 19, 2016 | AOpen F1713 (Silver) 17 in. Flat Panel LCD...
He external DVD player does not work how do I get an external DVD player to work
To work on what? If it is a generic, slimline external drive it should , it it is USB fitting, have a USB DATA CABLE AND A USB POWER CABLE. They do not require additional drivers. Do you have both cables?
If the device is 1394 firewire the same should apply I BELIEVE.
If you need more information can you please add thedetails of the hardware devices.
makes and models of the vari
Jun 18, 2015 | Televison & Video
How to build pentium 2
well first you need to get the following ..
  • AOpen HX45 Computer Case
  • Abit BH6 motherboard
  • Pentium II processor
  • 128 Mbyte, 100 Mhz, 8 ns, PC-100, 168-pin SDRAM
  • Focus 2001W Keyboard
  • Logitech M-S34 2-button PS/2 mouse
  • Four 9-inch cable-ties (also known as zip-ties) Garbage bag twisties will do, but won't look as good.
  • ATI Xpert@Play 98 with 8 Mbytes Display Adapter
  • AOpen 7277c 17" SVGA monitor
  • Panasonic 3 1/2" 1.44 MByte floppy drive
  • Maxtor 9136008 11.5 GByte, UDMA, EIDE hard disk drive
  • Toshiba SD-M1102 DVD drive
  • Additional IDE cable
  • AOpen FX-3D Plus ISA PnP Sound Board
  • MLi 699 Speakers
  • AOpen FM56-P PnP PCI V.90/K56Flex 56K MODEM
  • Windows 98 OEM
  • ATI DVD Player CD
Aug 13, 2014 | Computers & Internet
Dvd player just stopped working, followed by a burning smell
The problem is more than likely on the power supply board in the unit. The likely issue is a shorted capacitor, regulator, or diode. If you are handy with a meter you will need to check the parts on the above mentioned board.
Sep 17, 2012 | AOpen DVD Player (AOPDUW1608CG) Burner
I have a JVC surround system, I have power to both the DVD player and the Subwoofer but no sound. Wheni plug in earphones to the dvd player there is sound but nothing when unplugged. Could it be the S
You must have an external cable connection from the DVD audio output to the surround DVD input. As well there should be an output from the surround marked subwoofer. Connect them with the proper cable
Apr 04, 2012 | JVC TH-S8 System
It wont turn off
This could be probably you might have used a CD or DVD that had reading problems. If yours is a PC and not a laptop then unplug the power connection to the DVD drive, boot up the machine once and then shutdown the PC again and connect the power cable again to the DVD drive. This should fix your problem
Mar 07, 2010 | AOpen DVD Player (AOPDUW1608CG) Burner
Using s-cable...no sound...Please help!(to Telefunken lcd tv)
You won't have any sound. the s vidio cable is for video only. You need to use Your computer speakers.
May 25, 2009 | AOpen DVD Player (AOPDUW1608CG) Burner
Drive light gets stuck on at reboot
Try swapping the Jumper block ( Small plastic pin connector ) on The Back Of the DVD Drive. If using both Hard-Drive And DVD Drive on the Same IDE Cable. The DVD Should be set as Master And Hard-Drive As Slave, Or Vice versa.
Failing This, put The Hard Drive On Primary IDE Channel, And DVD On Secondary Channel.
These suggestions, have been made as it appears from your problem listed, that the 2 drives Are Conflicting with each Other.
Finally, is to try a different 4 pin ( Molex ) power cable to either device/Drive. if you have a single rail Power supply unit. the 2 units sharing a joint power cable, may be draining the PSU.
Hope this helps.
Mike @ compurepair.
May 11, 2008 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
Aopen help
It's very possible that while you were swapping out the dvd-rom you in bumped other data cables & power cables to other devices, just enough to cause the bios not to see them. Re-check all connectors & power cables. Start the system. Still no windows? Enter the bios make sure your devices are showing up. Like your hard drive floppy & dvd-rom. If you have to pull the cables off & reconnect them.
Jan 23, 2008 | AOpen MX46-533V (91.89U10.061) Motherboard
Won't burn
Check which flate cable do you have for its connection. AOpen recommendation is for 80-wire ATA-66/100 cable. In case this is not the cable you have, you should replace it. (The ATA/66/100 IDE cable is made from 80-conductor wire with 40 pin connectors, providing the superior ground spacing required by the ATA/66/100 specs, and allowing the full 100 Mbps burst transfer rate). Another AOpen recommendation is to configur the unit as a "Master" and not as a slave. Good luck
May 05, 2006 | AOpen DUW1608/ARR (914ID37002) DVD±RW...
Computers & Internet Logo
56 people viewed this question
Alun Cox
David Payne
David Payne
